Camaro Research Group Discussion => Restoration => Topic started by: onekidbill on April 05, 2021, 11:05:41 PM
Title: 68 Z28 Cowl Plenum fire wall pics
Post by: onekidbill on April 05, 2021, 11:05:41 PM
Looking for any pics of the fire wall hole for a cowl plenum air system. I'm restoring a 68 Z and it has a hole where it should be along with all the right screw holes. Just want to verify.
Title: Re: 68 Z28 Cowl Plenum fire wall pics
Post by: firstgenaddict on April 06, 2021, 12:02:28 AM
They were dealer or customer installed, I have seen one that had holes drilled across the area - and a couple which someone used a drill to out line the opening and then a chisel to break the connecting sliver. They came with a template, if you search for the cowl plenum template I am sure you will find a photo.
Post by: onekidbill on April 06, 2021, 09:52:40 AM
I'll check it out. Thanks.
Post by: MO on April 06, 2021, 08:43:39 PM
Check this out.
http://www.camaros.org/forum/index.php?topic=9900.0
Post by: onekidbill on April 06, 2021, 11:58:36 PM
Thanks. That's just what I was looking for. 👍
Post by: 68camaroz28 on April 10, 2021, 06:47:17 PM
I have some pics of ours u can view here.
https://www.camaros.net/threads/time-for-another-68-z-28-to-be-restored.182584/page-51#post-3284377
