Camaro Research Group Discussion => General Discussion => Topic started by: WaltZ on February 27, 2021, 03:33:48 PM
Title: 69 Steering Column Upper Bearing NON-TILT
Post by: WaltZ on February 27, 2021, 03:33:48 PM
1969 Camaro NON-TILT upper bearing replacement in steering column.
I was hoping to replace it while I have it apart.
Any Suggestions on removal and replacement, other than live with the slight wobble..
Thanks in advance.
Title: Re: 69 Steering Column Upper Bearing NON-TILT
Post by: WorkinProgress on February 27, 2021, 04:40:20 PM
Possibly the '69 Chevrolet Overhaul or Service Manual will tell you the procedure. Those manuals also list the specialty Kent Moore tools you may need.
                           - Warren
Post by: KevinW on February 28, 2021, 08:24:10 AM
Is there something wrong with it, that a good cleaning in place and re-lube won't fix?
