Camaro Research Group Discussion => General Discussion => Topic started by: 1967RS/SS on January 06, 2021, 05:43:26 PM
Title: Radius rod forward bracket to frame screw
Post by: 1967RS/SS on January 06, 2021, 05:43:26 PM
Im trying to add a radius rod to my car.  On the forward bracket, what does this tapered screw in to in the frame?  Right now I just have about a 9/16" hole, too big to catch any threads.  Is there a cage nut like the front leaf spring perch?  If so, how do I get it in?
Title: Re: Radius rod forward bracket to frame screw
Post by: hrlyfxdl on January 07, 2021, 09:16:33 AM
I pulled this from the 67 Camaro AIM, looks like the bolt passes through the hole and has washers and a nut holding it. Sorry if this is incorrect.
Post by: Mike S on January 07, 2021, 10:08:02 AM
 If I remember right, I think there is a threaded blind insert nut in the side hole for the bolt to screw into.
I'll check my '67's later.
Post by: 1967RS/SS on January 07, 2021, 11:46:50 AM
Dang, it's going to be tight getting a nut on this screw (#19 in the AIM page provided).  I can only fit one finger in the frame hole to hold a nut.
Some type insert nut would be easier for sure.
Post by: 169INDY on January 07, 2021, 01:21:41 PM
NUTSERT. Fastenal SKU 0128201
Hard part is the install tooling; Commercial or DYI
Post by: 1967RS/SS on January 07, 2021, 01:40:53 PM
Thank you for that part number.  Can you elaborate on this: "Hard part is the install tooling; Commercial or DYI"?  Is the tool needed for this nutsert different than the common "OTC" install tools?  Thanks
Post by: Mike S on January 07, 2021, 01:42:36 PM
Yep....I checked and see the round collar of the blind nut. View C in the above diagram confirms that.
Post by: 1967RS/SS on January 07, 2021, 01:47:22 PM
Thanks guys!  Now I get to buy more tools!!!
Post by: firstgenaddict on January 08, 2021, 03:07:37 PM
RIVNUTS... I think the entire kit from Finish Masters was about $100.
(https://nastyz28.com/attachments/resized_20190925_163747-jpeg.85210/)
(https://nastyz28.com/attachments/resized_20190925_163143-jpeg.85211/)
(https://nastyz28.com/attachments/resized_20190925_163136-jpeg.85212/)
(https://nastyz28.com/attachments/resized_20190925_163824-jpeg.85213/)
Post by: Gars68Tux on January 09, 2021, 04:58:22 PM
Quote from: 1967RS/SS on January 07, 2021, 01:47:22 PM
A special installation tool isn't needed. There's several videos on Youtube .
