(http://www.camaros.net/showroom/data/500/266.jpg)
Isnt the date code to late for a 67 Z
Mike -
I compared your photo to my original 266 distributor (dated 7A25) and it looks real to me. I would run it by Jerry for an expert's opinion.
Quote from: Lukes 69 z28 on April 01, 2007, 04:39:19 PM
No. July 20, 1967 would work for a '67 Z/28 or an early '68 Z/28.
Quote from: 1968RSZ28 on April 01, 2007, 05:09:19 PM
Of course, I would have Jerry verify that this is a "good" date for a 266 distributor.
It's real and a good date. This one only came in early 68 Z28s. It's the same one that's in my white survivor.
Is it for sale? We're always looking.
Jerry
I made an offer on it and wanted to make sure it was good. Too late for my car, but I'll use it until I find or trade for one that works for me.
Thanks for the info, I appreciate it.
Well I got it today and it's the real deal. The wire that goes to the coil is cut as seen in the picture.
It is also missing the vacuum advance.
Jerry
Do you have any earlier 266 distributors for an 05D 67z?
How much to send this one out to you for a rebuild and correct parts?
Mike J
Mike -
I'm curious, how much did it cost?
Paul, Mike may not want to disclose what he paid, so I can relay my current experience with these distributors. This one was offered to me and another '67 Z guy that I know a few weeks ago before the Team Camaro ad but I passed due to the date and the fact that I have a few 7A25 dated units now. Given that it's a '68 only date, I put the value at between $750 and $1,000 as is. The '67 dated distributors are the hardest part to find for a '67 Z and very few change hands. I bought 2 recently for $2,500 each I am waiting on delivery of a third that I just paid $2,750 for. I was offered $5,000 for one a few months ago.
hey jonesy,
i own what i believe is the latest cowl tag dated 67 z...07c...can i assume your distributor is too late for this car?...wasnt the last day of production july 21?...anyway, i do believe i have atleast 1 and maybe 2 others of these distributors...i can check the dates i have if you are interested in a trade...what would be the typical time between distributor date and cowl tag date ??? thanks
I have the last one built as 07B,
JM
Hey Jerry,
Im certain you have my info on my 07c 67 Z.... I did give you the info. on this car a year or so back when I was at your shop. I actually gave you a pencil tracing of the cowl tag and hidden vins. Im out of the country at the moment, but when I get back, Ill give you a call and forward a foto of the cowl tag if youd like. Im sure Kurt has this in the database and I believe Jon Mellow knows of this car also. Its a 17,000 mile white car...low option...with shoulder belts...and cowl plenum...I got a complete dated NOS MO 302 from Smokeys auction with the car. Ive actually posted on camaros.net in the past asking if there were any other 07c cars known. Unfortunately the day you were at my garage, I only had the other 2 Z,s there...I was in the process of changing garages and did not yet bring this car home yet...so to speak...I wish you could have seen it. I did mention it in passing while you were there. Could you double check your records and let me know if you need the info. again. Anyway, can I assume this distributor will not work for my car. Too late??
thanks, max
I paid a little more than what Zedder said. It is a very clean original unit.
Max
I am not sure if this date is good for that late of a 67. I just wanted a real one for my car.
I would trade for the right one.:)
Hey jonesy,
I am hoping Jerry chimes in to let me know if your distributor will work for my car...I suspect not. The NOS motor I got with the car is complete from carb to pan including exhaust manifolds, and is dated perfect for my car and has never been stamped with a VIN, unfortunately the distributor included is the only part that is not correct on the motor. (and of course the most expensive part!!)
I am in South America until May 1 anyway, but I will check the distributors that I have when I get home and let you know. thanks
Quote from: Iluv69s on April 12, 2007, 06:25:33 AM
Hey Jerry, Im certain you have my info on my 07c 67 Z....
I think this is the trim tag for your car:
(http://www.67z28.com/images/hommel.jpg)
Max,
What is the engine date? The distributor has to be before that. :)
hey dj
thanks for chiming in....yes, that is actually is my trim tag.... Im not crazy after all!! You guys are really on the ball!! by any chance do you have a foto of my motor stamp also? I am in brasil at the moment and dont remember off the top of my head what the stamped date is...for some reason, im thinking V0706MO.
Thanks Kurt also...but I'm also not sure how the distributor dating went off the top of my head...I know some component dating begins in October, others corrospond to A as January...Can I assume G is July, right? Although I believe I know more than the average guy about camaros, Im not so good on the numbers and dates...I refer to the books quite often...and this website!!
Therefore this distributor wont work for me ?? :'( :'( :'( :'( :'( :'( :'(
Also Kurt, I havent forgot you on the other numbers of my cars...and that BB rear date issue. I have been traveling alot lately, so I just havent had the time...will let you know when I return home.
as always thanks again CRG!!
Hey Max, there are several 07C cars in the CRG database. It is a valid date on a trim tag. Yours is the only 07C car in the '67 Z Registry although interestingly there are a couple of 07B cars with VINs later than yours.
That 7G20 '266" distributor is not right for your white '67. It would be used in a '68.
-Jon
