Camaro Research Group Discussion => Garage Talk => Topic started by: Brent on August 13, 2020, 02:01:42 PM
Title: Vinyl Top Install Cost?
Post by: Brent on August 13, 2020, 02:01:42 PM
10 years ago I could get a vinyl top installed for $250; now I am being told $1K.
Does anyone have any recent experience having one installed?
The car currently does not have a vinyl top so the molding pins would have to be installed too
Thanks!!
Title: Re: Vinyl Top Install Cost?
Post by: fiveforty on August 14, 2020, 07:15:27 AM
Was just told 500 for labor. The glue is very expensive.  A decent original type top  is $250 from Heartbeat city. They have all the pins and clips also. In the same boat as you. Having one done but have not pulled the trigger yet.
Post by: x66 714 on August 14, 2020, 08:58:41 AM
I had to have a top made at SMS because they were the only place that had parchment & I also needed the seams to be in the correct location. Everybody else had white. 400.00 for that top plus install (haven't priced yet)....Joe
Post by: HOT3O2 on August 14, 2020, 10:41:39 AM
I assume that when you have a new vinyl top installed you have to remove the front and rear window to do it. Is that right?
Post by: 169INDY on August 14, 2020, 11:28:10 AM
I have had a Shop replace a 68 Camaro V top w/o glass removal, but as you suggest I would be easier & better for the installer
Post by: KurtS on September 09, 2020, 04:06:39 PM
You can install it with contact cement. It's the pins that are the pain....
