Camaro Research Group Discussion => Restoration => Topic started by: ALLZS on August 03, 2020, 07:37:00 AM
Title: hood insulation pad
Post by: ALLZS on August 03, 2020, 07:37:00 AM
what brand of hood insulation pads has  any one been using with good fit
Title: Re: hood insulation pad
Post by: Petes L48 on August 03, 2020, 09:11:46 AM
It isn't installed yet, but this one came recommended.  I believe you have to buy through a vendor.  They can be found on their "About" webpage.  I had mine delivered/brought to a swap meet to avoid freight cost.
https://www.remautoinc.com/products.php
Post by: firstgenaddict on September 23, 2020, 07:50:23 PM
The molded insulation is the one to buy, it is more expensive and must be shipped truck freight vs the non molded, however if correctness is desired, molded is the only way to go.
Post by: upscope757 on September 24, 2020, 05:29:47 AM
Completely concur with the molded hood insulation. Will run you close to $100, plus about $100 shipping. I got mine from National Parts Depot. Pics attached. This variant works for both flat and SS hood. They have different one available for the cowl hood.
