Camaro Research Group Discussion => General Discussion => Topic started by: bad69 396 on July 13, 2020, 03:09:49 PM
Title: 69 new volt meter console gauge install
Post by: bad69 396 on July 13, 2020, 03:09:49 PM
new volt meter my instructions are not very detailed i do not know how to connect power to volt meter i can not use the old amp system wiring for volt meter,has any done this install yet,any help and directions are helpful.it has three pegs,one is for ground and the other two prongs i do not know? thanks
Title: Re: 69 new volt meter console gauge install
Post by: 68 Ragtop on July 13, 2020, 07:08:52 PM
I gave a link to the manufacturers instructions on Team Camaro to this same question. Was that you?
Installation Instructions:
1. Disconnect your battery. If you have stock wiring in your car, you must remove the connector
containing the black wire and the black with white stripe from your stock ammeter. Next, you'll want
to disable the black wire and black with white stripe wire as they are 'battery hot" all the time. Be
sure that they do not become grounded at any time. AAW suggests that they be removed from the
dash bulkhead connector assembly at the firewall altogether.
2. FIGURE 1:
This is how the new voltmeter assembly looks as it is shipped to you. It is already mounted onto
a new gauge "mounting plate". Continue your installation by unplugging the connector that
contains the dark green and pink wires from back of your temperature gauge, and then by
removing the complete existing rear gauge plate assembly containing the ammeter and
temperature gauge from your original console gauge housing. Next, remove the original
temperature gauge from the original gauge plate assembly, and re-install it onto the new AAW
gauge plate/voltmeter assembly. Please play particular attention to the orientation of the white
insulator, connection blades, and hardware that connect the temperature gauge into the plate
assembly. Be sure to re-assemble it the same way. (See FIGURE 2 for proper configuration)
3. FIGURE 3:
This rear view shows the new voltmeter gauge as it comes installed into the gauge "mounting
plate". The upper stud on the LH side (as you are looking at the studs coming through the back
of the mounting plate) is merely for mounting purposes. The two studs on the RH side are
your gauge wiring connection points. (See figure 4 below)
4. FIGURE 4:
This view shows how the gauge wiring connections must be made. The wiring to the top stud
with the black paint daub on it should be attached to a good known chassis ground. The wiring
to the lower stud with the red paint daub on it should be attached to a "keyed 12 volt fused
ignition source" wire. If you are using our Classic Update harness, this wire is located in the
500664 console harness. If you are using an original 1968 or 1969 Camaro console
harness, connect a jumper wire from the location of the pink wire on the temperature gauge to
the stud with the red paint daub.
5. Lastly, it is time to reinstall the newly completed rear gauge plate assembly containing the new
voltmeter and the original temperature gauge back into your original console gauge housing. Be
sure to re-attach the connector that contains the dark green and pink wires to the back of your
temperature gauge. Your installation is now complete.
Post by: Gars68Tux on July 14, 2020, 03:33:29 AM
Hey James, Garth here...lol I seen your reply at TC and didn't realize it was a link! https://www.camaros.net/threads/69-camaro-new-volt-gauge.477871/#post-1783237471 I imagine "bad 69", AKA "Camarostrong" had the same experience.
Yep, Kurt mentioned trouble with seeing links and such....
Post by: 68 Ragtop on July 14, 2020, 06:28:24 AM
Updated TC post to make it clear that it was a link. TC and CRG links look different.
Click here for a link to the manufacturers website instructions:
https://smhttp-ssl-87263.nexcesscdn.net/pub/media/productattachments/files/92969249_510121_4.0.pdf (https://smhttp-ssl-87263.nexcesscdn.net/pub/media/productattachments/files/92969249_510121_4.0.pdf)
Post by: bad69 396 on July 14, 2020, 07:19:52 AM
thanks very much guys,i did not buy the aaw voltmeter its another company and did not come with new panel,i just drilled new holes to compensate for new voltmeter, it has the three prongs two are light metal color and the other is is a copper color i think its for a ground.  thanks
