Camaro Research Group Discussion => Decoding/Numbers => Topic started by: Rich 5150 69 on March 30, 2007, 09:54:55 PM
Title: New to this site!
Post by: Rich 5150 69 on March 30, 2007, 09:54:55 PM
 Hi, new to this site, having owned this `69 RS/SS since the mid eighties, its getting time to restore it, most everything on it is original except carb, water pump, alternator,  and maybe distributor, trim tag as follows
ST69  12437LOS126238
trim 725        57E pnt
10B              J100
HB stamped 350, can`t tell whether its a 386 or 388 block, turbo 350, 12 bolt BL axle. All the usual SS items are there. Can you guys explane what the J100 code is, and if Kurt wants this in the data base, to let me know.     Rich
Title: Re: New to this site!
Post by: 1968RSZ28 on March 31, 2007, 03:34:41 AM
Hi & Welcome Rich -
Please read this link to answer your question about the LOS (Los Angeles) body scheduling code:
http://www.camaros.org/numbers.shtml#CowlTag
Have fun!   :)
Post by: KurtS on April 02, 2007, 01:38:42 AM
Rich,
Your car is already there (from a post you made on camaros.net). :)
Can you post or email me the VIN, the trans code, and the rest of the axle code?
Thanks!!
Kurt
Post by: Rich 5150 69 on April 02, 2007, 09:04:26 PM
Do you want date codes as well..?
Post by: KurtS on April 03, 2007, 01:04:15 AM
Yes. :)
Post by: Rich 5150 69 on April 09, 2007, 09:01:46 PM
Axle code BL1004G,  when I can get my head down into the back  of the fire wall I get the engine code and date
Post by: BULLITT65 on September 17, 2017, 02:03:02 PM
Hey Rich, I also have a 10B L.A. car and I am looking forward to seeing you update this thread on your car. ( BTW mine is also Dover white)
Glad to see you back
Post by: Rich 5150 69 on September 22, 2017, 05:11:50 AM
ST69  12437LOS126238
trim 725        57E pnt
10B              J100
If I understand the date coding right, and (if) Gm scheduling followed the calendar year, this would put the build at Friday Oct 10, 1968  the 100th car on the line...?  Only trying to get it right so I can verify the rest of the cars date codes on the normal wear parts.. ::) How long did the 69 model year run, and is this an early 69 or late.. way to many questions... :o
Post by: 69Z28-RS on September 22, 2017, 07:27:41 AM
It *may* have been the 100th car on the 10th PRODUCTIOn day rather than the 10th calendar day...
Post by: Rich 5150 69 on September 22, 2017, 12:57:10 PM
Understood...by GM`s calendar...!
Post by: BULLITT65 on September 22, 2017, 02:00:12 PM
Intersting trim tag.
Mine is:
ST 12437LOS130103,
but my date is:
10B     H396
Post by: Rich 5150 69 on September 22, 2017, 03:34:00 PM
Quote from: 69Z28-RS on September 22, 2017, 07:27:41 AM
And we have no idea what that is, if I`m correct...?
Post by: KurtS on September 25, 2017, 01:27:21 PM
More than that. That's when it was initially scheduled - it could have been built a day or two off.
Post by: Petes L48 on September 25, 2017, 04:54:35 PM
The production date listed on the NCRS reports - anyone know what that date is based on, and is it an actual date or approximate like the LOS Fisher Body scheduling code?
Post by: ZLP955 on September 25, 2017, 07:01:30 PM
My understanding is that the production date shown on the NCRS letter is the date GM officially considered the vehicle as completed, and invoiced the ordering dealer. It's often several days (at least) before the date the vehicle was actually collected for shipment, but the logistics of transporting so many vehicles away from the assembly plants explains the delay. Not sure there is a clear definition of when the car is considered 'complete' (especially if it triggered an invoice to the dealer, there may have been a 'substantially complete' build stage) but would think it reasonable to expect it was when the vehicle left the production line and passed quality control.
Post by: william on September 26, 2017, 03:29:35 PM
I have been working on 'reverse-engineered' 1969 production schedules for many years. Data used to compile this includes:
•   Chevrolet 'last car of the month' data for both plants
•   Known production rates of 57 cars/hour at Norwood late Sept '68 through 1st week April 1969
•   Print dates on Van Nuys body & chassis broadcast copies.
•   A very few factory to dealer invoices
Each of these sources requires interpolation.
The 'last car of the month' VIN was recorded at the end of the 2nd shift on the last financial day of the month. It wasn't always the last calendar day of the month. The successful completion of roll-test marked the car as complete. However, cars were not final-assembled in VIN order. The next car through roll-test could have an earlier VIN; on occasion several hundred units earlier.
People that worked at Norwood are emphatic about the production rate of 57 units per hour. It's a simple calculation but requires knowing how many work days there were. Did they work only 1 shift on Christmas Eve? Did they work the day after Thanksgiving? For the most part it works out but on occasion requires making assumptions about overtime or shutdowns. It works for January '69 if I assume production started on 2nd shift January 2nd and they worked a full Saturday the following week.
All bets are off after Firebird production moved to Norwood mid-April. They probably still built 57 units per hour; how they were allocated is not known.
It's been stated many times but bears repeating: Body & Chassis Broadcast Copies were generated by Chevrolet Assembly after the completed body was received into the body bank. The date on them is when they were printed. Typically the date is a calendar day or two prior to completion.
Factory invoices are rare. The CRG was fortunate to locate almost 200 dealer copies from Norwood for the 1969 model year. There are two key dates on them:
•   Date shipped
•   Date of execution
The invoice from ZL1 #1 has been around for years. It's known ZL1s #1 N569358 & #2 N569359 were delivered on Christmas Eve, 1968 from a 1989 interview with Fred Gibb. The date shipped on the #1 invoice is 12/30/1968, date of execution 01/09/1969. The date of execution is obviously irrelevant. In this case the cars were expedited, shipped soon after coming off the line. But in comparing almost 200 data points from the invoices to a production calendar, only 11% shipped the same day they were completed. 34% shipped the next day; 12% shipped 2 days later. That means 43% shipped 3 days or more after production; a few waited 11-12 days.
Conclusion: The "GM Official Production Date" on the NCRS report is from GMAC shipping info and is likely the date shipped. The actual production may be the same date but most likely is not.
I expect that some internal paper document for each VIN was time/date-stamped as the unit completed roll-test. However that data was not relevant outside the plant so there was no need to disseminate it. I believe dealers received reports on assembly scheduling, if not actual production. There are internal Yenko Chev docs around with columns titled 'body build date' 'body comp date' and 'ship date'. Some are filled in; many are not. But the dates appear to be estimates; they show N578878 shipping February 7th when it could not possibly have been built by that time. Other close VINs shipped February 20th.
The production schedules will always be a work in process as more data is acquired. Lately, I only occasionally have to make adjustments it so it must be getting close.
Post by: BULLITT65 on September 26, 2017, 03:55:59 PM
Thank you for putting the time into this, and one better explaining it to us.
Post by: Rich 5150 69 on September 26, 2017, 06:47:10 PM
Wow William, did not know it was that involved, great writeup...Thanks..!
Post by: Petes L48 on September 26, 2017, 07:34:05 PM
Many thanks for such a detailed reply and your tireless research,William.
Post by: KurtS on October 10, 2017, 09:45:49 PM
Quote from: william on September 26, 2017, 03:29:35 PM
This change in order occurred in the Body Bank. IMO, it's unlikely that VIN's were out of order by that much, because they were always pulling from all 6 lines in the bank.
Post by: 69Z28-RS on October 10, 2017, 10:04:28 PM
YIPPEE!!!!    :)
... sorry..  just happy to again be reading CRG posts...  :)
Post by: william on October 12, 2017, 05:07:44 PM
None of us was there, so when I started working on this I asked someone who was-John Z:
Yes, a body could be held (only in the Body Bank) for a full shift, and a sharp bank supervisor was always prepared to do that if he had to; however, the body was VIN'd  before it was released into the bank, so it was possible to see some pretty significant VIN offsets -vs. actual physical line position. With a nicely-balanced schedule, up to a six-unit difference wouldn't be unusual, and ten or twelve tells you that there had been excitement of some sort up in the Body Bank.
This is important because the last VIN of the month is the basis for reverse-engineering the calendar. If it so happened that the car selected as last VIN of the month happened to be significantly out of sequence, it messes up the calendar. It is possible that happened for the 1969 model year. Knowing the last VIN of a month also reveals the first VIN of the following month. For December 1968 last VIN-first VIN works out to 18,125 units. Divide that by 20 work days equals 906 units/day, within the plus/minus 6 VIN margin. However, that calculation does not work out that closely for every month.
As I stated, a work in process. Got another data point so more number-crunching.
Post by: KurtS on October 12, 2017, 11:14:26 PM
Yup. My point (and John's) is normal is a very small range, mostly less than 10 or 12.
Your point is true - one of those oddballs could be the VIN that was recorded. Something for sure happened to the late NOR 68 recorded VIN's - those numbers are way off.
