Camaro Research Group Discussion => Maintenance => Topic started by: jvb6648 on April 02, 2020, 03:51:14 PM
Title: Ignition switch wires
Post by: jvb6648 on April 02, 2020, 03:51:14 PM
I need to know what colored wires go to which terminals on the ignition switch. I think I figured it out but need to be sure. I think I have it figured out but not sure of the pink with black stripe and the green.
Title: Re: Ignition switch wires
Post by: bertfam on April 02, 2020, 04:09:21 PM
Green goes to the GND terminal and the pink goes to the IGN terminal. However, I've not seen a pink with a black stripe. It should only be pink.
Post by: jvb6648 on April 02, 2020, 05:50:27 PM
The pink with the black stripe is a 20 ga. I think it might go on the center KEY + terminal.
Post by: bertfam on April 02, 2020, 06:03:19 PM
Yep. You're right. I forgot about that one. From Jim Shea's web page (see attached).
Post by: jvb6648 on April 02, 2020, 10:24:19 PM
Perfect, Thank you
