Camaro Research Group Discussion => Originality => Topic started by: VINCE Z28 on February 24, 2020, 09:28:42 PM
Title: Original Tri Power
Post by: VINCE Z28 on February 24, 2020, 09:28:42 PM
Hey guy is this a original 1969 tri power air cleaner? And will a 4055-1 center carb. (Date is 103) hurt the value of a tri power?
Title: Re: Original Tri Power
Post by: VINCE Z28 on February 27, 2020, 01:00:42 AM
Do any of you guys know if this air cleaner is original?
Post by: Kelley W King on February 27, 2020, 08:55:13 AM
You have two parts. The base and the cover. The cover should have the silkscreen or signs of it. The original covers are also heavier. The hose on the base is not correct. There should be an elbow with with a screen inside the base. New lids are fairly cheap. Ebay usually has several which can give you  some idea of value.
Post by: VINCE Z28 on February 27, 2020, 10:58:58 AM
Thanks Kelly. She is asking 2900. for cleaner, carbs and intake. The center carb is 4055-1 front and back is 3659.Vince
Post by: 68camaroz28 on February 28, 2020, 07:27:44 PM
Quote from: Kelley W King on February 27, 2020, 08:55:13 AM
Agree with Kelly!
