Does a 1968 302 use the lower plug wire looms with 2 slots or 3? Thank you, Joe
UPC 6
B5
3, assuming you mean on the valve covers,,3 slot dividers prior to the upper loom brackets.
So the one on the left is correct? Do you know what the on the right is for? Thank you, Joe
At some point I remember a thread about use of 2 vs. 3. I just went off the assembly manual. Are those survivors off your car? Mines a Norwood build, if that means anything.
Since it was supplied with the engine, it shouldn't matter if Norwood or LA. Mine is LA. Was just looking through parts & thought I would find out for sure. I'm not sure where the 2 wire ones came from. The 3 wire ones I purchased from Chevrolet in about 1977.
What do you have on your engine?...Joe
I put 3 both sides, came as a set, stamped, bk off the top of my head,I think.
Not original to the car, aftermarket.
