Quick question how do you remove the bezels on the dash around the cigarette lighter; wipers; ignition; lights?
Do they unscrew is there a specific tool I need to get them off any help appreciated thanks.
I'm a bit confused as to how they work some say you have to remove the whole switch to get them off
and some people say you don't.
Go to the downloadable AIMs link in this forum and get the manual for your car. Check out UPC sections 1,6, and I think 12 for diagrams which should clarify those for you. The lighter has a threaded sleeve on the backside of the dash, I think the rest thread from the front.
Thank you Pete.
I was able to replace them all except the lighter in which I will do another time
after doing the others everything works fine except the washer pump I must have
knocked a wire off what else could it be? thank you for your help.
