Camaro Research Group Discussion => Originality => Topic started by: john302 on February 01, 2020, 05:53:45 PM
Title: Radiator fan shroud clips
Post by: john302 on February 01, 2020, 05:53:45 PM
Did the Harrison factory install the radiator fan shroud clips before they painted the radiator? Thinking they did but not sure. Thanks
Title: Re: Radiator fan shroud clips
Post by: Mike S on February 01, 2020, 07:35:58 PM
Hi John,
  I was in the garage today and removed the clip on my 67 survivor with a UO radiator. I assume you meant the clip on the right side bottom that hooks to the core side and the other clip side, using an arrow shape protrusion, that gets hooked into the radiator side mount.  There is definitely full coverage paint on the radiator surface under the clip. Inspecting the clip itself it has no traces of ever having black paint. It has an evenly oxidized finish exactly like the dry and oxidized texture of a part that was originally phosphate. The left side smaller clip is definitely zinc phosphate.
Post by: john302 on February 16, 2020, 02:29:52 PM
Thanks for the info
Post by: 169INDY on February 16, 2020, 02:46:26 PM
1968 302 LOS 12D build as found.
