Camaro Research Group Discussion => Restoration => Topic started by: vabeach56wagon on September 18, 2019, 12:19:08 PM
Title: Door Jamb courtesy light/key buzzer switch
Post by: vabeach56wagon on September 18, 2019, 12:19:08 PM
I have purchased and received a reproduction/replacement LH door switch. It has a rubber sleeve over the plunger. Is this simply to protect the plunger during shipment or was the sleeve installed originally? Doesn't seem to show up in any illustration in the AIM or elsewhere.
Thank you
Title: Re: Door Jamb courtesy light/key buzzer switch
Post by: bertfam on September 18, 2019, 12:51:32 PM
You mean like this? (See below)
Nope. No sleeve originally. Remove it and install. Or, if you're not concerned about "originality", you could probably just leave it on there. Probably won't hurt anything.
Post by: vabeach56wagon on September 18, 2019, 02:07:40 PM
Thank you...I'll remove it....may as well get some of the details right!
