Camaro Research Group Discussion => Maintenance => Topic started by: Wallace on March 13, 2007, 12:32:00 PM
Title: 1969 Camaro brake metering valve
Post by: Wallace on March 13, 2007, 12:32:00 PM
I have an origonal '69 ss 396 with front disk, rear drum brakes.  I am servicing the brake system and got to the metering valve, which is inline with the front disk lines and is attached behind the master cylinder.  I am going to rebuild the unit from a kit I ordered from Heartbeat City.  My problem is that when I disassembled the valve I didn't account for spring pressure and parts came loose before I could account for their location.  Does anyone have a schematic diagram or description for the assembly of this unit?
Any help would be appreciated.
Wallace
I found this link that answered my question.
http://home.pacbell.net/camsdad/Brakes/DSC03368.JPG
Maybe this will help someone else.
Wallace
Title: Re: 1969 Camaro brake metering valve
Post by: JohnZ on March 14, 2007, 11:05:15 AM
Mine quit working too and needs to be rebuilt, but I haven't gotten around to it yet; here are a couple of photos I grabbed a year or so ago of disassembled metering valves, but I don't know which one shows the correct parts sequence. Let us know how your rebuild goes and if your kit has the right parts in it.
Post by: Wallace on March 15, 2007, 08:29:13 AM
Thanks for the photos JohnZ.  The top one illustrates the workings of my valve.  I removed this valve several years ago because it was leaking, and replaced it with an adjustable  proportioning valve....not a good idea.  I am glad I saved the original brake lines and bracket.  After I freshen up the rubber it should be an easy install.   I will keep you posted.
Wallace
Post by: m22mike on March 20, 2007, 03:36:30 PM
Here is yet another shot of the guts, this one was just disassembled and I was carfull to lay out the parts in order.
Wallace, a question about the kit from Heartbeat. What all is in the kit? Does it include the small cup seal that seals the shaft at the back of the valve ?
                            Thanks Mike
(http://i18.photobucket.com/albums/b107/m22mike/DSCF3015.jpg)
Post by: Wallace on March 21, 2007, 07:58:23 AM
Thanks for the photo Mike.  That is the identical valve that I have except I do not have the washer or the cup seal which go on the back end.  The kit I ordered from Heartbeat City was for the other style metering valve, so I sent it back.  They told me that they didn't have the kit for my style valve...bummer.  I guess I will keep looking for one.
Wallace
Post by: GaryL on April 19, 2007, 07:39:05 PM
I got my metering valve (the round one) done by Karp's Brake in So. Cal. (909)985-0800 for $65.
Post by: JohnZ on April 20, 2007, 09:46:30 AM
Quote from: GaryL on April 19, 2007, 07:39:05 PM
Does it work properly after the Karp's rebuild? My original is apparently stuck open, as I have big-time nosedive when braking, especially at low speed.
Post by: GaryL on April 20, 2007, 09:59:13 AM
Works fine as far as I can tell. No braking problems at all.
