This is on a 1969 Z-28 X-77 car on the drivers side attached to the bracket that hold the inner fender panel.
That's a water shield and is not available. The one in the picture looks like it can be cleaned up.
That's a shield for deflecting water away from the electrical connectors at the main harness on the firewall I believe. They're on every Camaro not just Z/28. Are you asking if the metal piece is available or is the rubber available? Last time I bought the rubber for the fender wells, that piece of rubber was in the kit......Joe
Early 67's do not have that shield. Repops makes a nice rubber replacement kit that has the white embedded strands like the originals. I no longer have to make my own.
Thanks for all the help guys. This 1 is torn up a bit but I will try cleaning it up. I will try to find a repop if I can . Thanks again Emo
A couple old threads on that splash shield:
http://www.camaros.org/forum/index.php?topic=7488.msg49666#msg49666
http://www.camaros.org/forum/index.php?topic=8610.msg59889#msg59889
http://www.camaros.org/forum/index.php?topic=11524.msg98548#msg98548
