Ello 8)
i start the restoration on my 69 Z28 ,the floor need to be fix it (front and rear) ,what is the best compagnie for the floor pan ?
for the value of my car the better is change all floor (one pieces) or fix the old one whit patch floor pan ?
Thank you! ;D ;D
I guess that would depend on how bad the floor is. Can you post some pictures? I'm a firm believer it try not to lose any more than you have to but sometimes you have no other choice....Joe
My Floor Pan :P
i cut all the rust :o
the both side are the same problem
Ello frends ::) do you use the floor pan from Dynacorn 1046A ?
Thank you
I've not had the occasion to replace one, but if I did I would likely use the AMD floor pan. I'm impressed with their quality and attention to details in the stampings I've seen.
http://www.autometaldirect.com/amd-floor-pan-w-braces-67-69-camaro-firebird-includes-convertible-plates-p-821.html -
Or use the right or left halves -
http://www.autometaldirect.com/amd-front-floor-pan-half-lh-67-69-camaro-firebird-p-854.html
http://www.autometaldirect.com/amd-front-floor-pan-half-rh-67-69-camaro-firebird-p-855.html
Definitely not for the timid sheet metal guy. Replacing the entire pan makes sense, unless you're into a lot of stitching on smaller panels.
Dom, go to Team Camaro and ask question in "body shop" forum along with reviewing Team Camaro "build" forum as many of the builds needed floor or partial floor replacement. I would not do anymore surgery to car before u know what best direction to go.
Thank you 68 camaro is verry appreciate 8) 8)
