is the 69 Camaro and the 70 chevelle cowl hood flapper frame the same part
No, the 70 chevelle SS was a vacuum operated deal as i remember. I had a 70 Chevelle SS and the flapper would open and close at idle if you had a big Cam in the engine.
The '69 ZL2 cowl induction electric solenoid is a common part that was also used on 70's Corvettes. Not sure if the frames will interchange but you can take a run at it. The smog era Corvette pieces are much cheaper than the '69 Z/28 pieces even if they are the same part number. ;)
