Camaro Research Group Discussion => Mild Modifications => Topic started by: 69aus on February 25, 2007, 11:41:16 PM
Title: zz502 into 69
Post by: 69aus on February 25, 2007, 11:41:16 PM
Anyone done this transplant? Does the 502 sump fit and is there any other clearance problems when fitting to 69. Also are there any headers that will fit without adjustment ? Are the smallblock engine mounts ok ?
Thanks in advance
Title: Re: zz502 into 69
Post by: sdkar on March 13, 2007, 08:19:54 PM
You can use either hooker headers (part # 2457) or if you have some extra money, go to Dougs headers (http://dougsheaders.com/tv/) for the 502 to fit in the 69 Camaro.  You will definitely need to change the oil pan to a 4 quart pan to clear the crossmember.  There is an oil pan offered that is specifically made for the 502 in a 69 Camaro.  Other than that, everything will fit fine.
Post by: sdkar on March 17, 2007, 10:51:43 PM
Here's what you need.
http://cgi.ebay.com/ebaymotors/GM-Performance-Parts-4-Quart-Oil-Pan_W0QQitemZ200089823315QQcategoryZ140690QQcmdZViewItem
