Camaro Research Group Discussion => General Discussion => Topic started by: z28z11 on November 11, 2018, 12:37:39 PM
Title: VN Z28 on Craig's List - KY
Post by: z28z11 on November 11, 2018, 12:37:39 PM
Interesting Z on Craig's List locally - documentation, NOM, but mostly there. Price could be better -
https://bgky.craigslist.org/cto/d/1969-camaro-z28-rare-find/6740914204.html
Title: Re: VN Z28 on Craig's List - KY
Post by: cook_dw on November 11, 2018, 02:34:35 PM
Known car locally.
124379L507747
Post by: VINCE Z28 on November 11, 2018, 02:57:28 PM
No mention of CE on the replacement motor and if that's the original paint the spoiler was add.
Post by: cook_dw on November 11, 2018, 06:07:00 PM
Original paint, trans & diff.  CE block.  Solid car.
Post by: ZLP955 on November 11, 2018, 08:19:28 PM
Quote from: VINCE Z28 on November 11, 2018, 02:57:28 PM
The first page of the ownership notes state original owner had the dealership install the spoiler
Post by: cook_dw on November 11, 2018, 08:52:05 PM
Thank you Tim.  It also mentions the CE block in the same verbiage...   ;)
Post by: BULLITT65 on November 13, 2018, 10:29:57 PM
I wonder why the heads would have been replaced? I assume Chevrolet would not have authorized that right?
Also intersting to see the heater hose clamp on the alternator. I know we have discussed that before, maybe it was a early L.A. part? (seems like other early Norwood cars did not have it) My 10B L.A. car does have it
Post by: JKZ27 on November 14, 2018, 06:16:46 AM
Quote from: BULLITT65 on November 13, 2018, 10:29:57 PM
If the engine dropped a valve, the head could have taken a real beating. Hard to say why both would be replaced unless there was an issue found with the other.
Post by: bcmiller on November 14, 2018, 06:55:20 AM
Not sure if those early 1970 heads would have screw in studs and guideplates, but if they do, that may be the reason why. That is a better setup than what it would have had originally.
Post by: Kelley W King on November 14, 2018, 07:37:54 AM
My 12A 69 L78 has a CE block cast June 11 69 with heads cast Feb 19 69. Owner history to 78 says it was purchased like that with 20k + miles and not ben apart since.
