Camaro Research Group Discussion => Originality => Topic started by: ALLZS on July 12, 2018, 05:41:30 PM
Title: fuel hose
Post by: ALLZS on July 12, 2018, 05:41:30 PM
what was the assembly line correct 3/8 rubber fuel hose from tank to line & line to fuel pump  used in 1969 was it a ribbed style or something different
Title: Re: fuel hose
Post by: firstgenaddict on July 12, 2018, 11:50:49 PM
Not ribbed
This one is marked
GM GAS 10028  =   October 2nd 1968  ~ off a CAR built 2nd week dec.
(https://lh3.googleusercontent.com/3h0ctnnl4uFYTjTIJnaEkLWE7kgEecR8u4zLXkAaN25coz6DsGKBQ-lQZ-JD0uqapEZpbNdr-dhrxfbsW4_PxqExrSsQ9xpvjL2m7z7_7FdcRivn6lASFEJ0K42VHV7xVlDbEAqa3TwclCJjQ0bbAHY8GdpeJN0YjKpvWG41us5FwnpTIXfhQm9jBENs8stu6G5HxCqypP1x9LicjYJBv2XsdhFWXwVHd-tResVvXTmyf7MuL8iB2vFmhEp6VGwZgUrPMF2O_W4eHFTWG7NMPZdQX5iYlOB3qNXIGgquPDJFp4CfFRvDxx_HiwmQ3bjTAYSdRY5zsZZLa7ruJ5AsvAA85zHNtR7RMKyl0opnIPj3-uDQuCOMuJjCFtnDdqj4xOFnA1qwkQFl_DY_6cYZ8IG50VsStrejjjAUy3eU5kqpP62OvWBm04bB1zdaR1DmjjqqK09dbvhI4etGHDRDzRfVH7npT2mk7cm7w-yDPBjqj0ZYPWj6ko68z3QiwoPs7CXkjltjo7b8tPgTwwjvoEOO9Q6vhvE3rHzpXHNTNUQ4dqfZJgPlbufXfxJW8w14UB2LV1L3L7gtH2Xf5tpJj594gZa_QxWwTucKUftMTL9Yl8T0OS9xv6yTHJb09VU7OnJDJAVc7bwM3vX63Y9glhzNxSEmV29sLQ=w1608-h1073-no)
(https://lh3.googleusercontent.com/iauOZJs6y3KdlVpcJterQ1UIANGiQDfaYmA0yAXlO4eeFYq9DUup0I5a95swvVIzifj_0-AoQM_tObgTPUhja59faguWmbOqTeg3MatByGvdiA-rShP8QciITjiGGEqk5h1IBrOhFcRadQaijR2QRO7Y2fLXwVLmRczK_dZsjkI3yKyyzVG8oIzJzaI-XsxKeeQGBCm9ea0V_70tAqOp2PFi5XXLFdz93q49KzywguGK1eyya5bcjXPyADJf22VzWKS1XrSAqxOIdiM2X9Tr7sQExQlU9wyCdjuKWy49M5x6leuT4dG0n1CMYAXiupHfx6mJDOuft8gEYYnkxDHkBI5A4_quM-yHkJzOJN9jgKihugk3I7WS3wFGmEVo681_Mz-iL7CneUp-Ch5YkdB6hHUjiDjKcLclakrhcafOpQaPp-1eAAenao8oFlsGGC9j8_AgpfvAnQ3kqVMQhmeR3pWV9f1J1O7dzFDVhOE7Px4x_A8LJTYhRuqDBTzzE-J0yXeVNolanEPIpGfAJZksstVe04Mj58EWYuD5nA9obXz6LLjipTPehO6xweEkciqedz3BD8vkxFkedhcS5dDLzJ9AeXImpCownDvBGo7OT7yOjzjrcePY_bxpf6s3CSEzeufAG6i6xp9fYa4YuUv1W5C8XN6tB_UsSA=w1608-h1073-no)
Post by: Danzo on November 04, 2018, 08:04:20 PM
Does anyone currently make this hose?
Thanks, Doc
Post by: Danzo on November 11, 2018, 07:55:57 PM
Anyone?
Post by: BillOhio on November 14, 2018, 10:56:47 PM
I think i got mine at heartbeat city. I am sure it says gm gas anyway
Post by: Danzo on November 16, 2018, 06:46:46 PM
This is the current hose that all the repo houses sell. Does yours look like this Bill?
Thanks.
Post by: Danzo on November 26, 2018, 06:08:14 PM
Can anyone shed any light on this?
Thanks,Doc.
Post by: 68camaroz28 on November 26, 2018, 06:38:27 PM
Quote from: Danzo on November 26, 2018, 06:08:14 PM
Thanks,Doc.
Doc, yes you are correct as that is what I see advertised often but it is not correct and Legends judging for example will deduct as not being correct. I would suggest you might be better off in just putting on a piece of black gas hose with no writing.
Post by: Mike S on November 26, 2018, 06:55:35 PM
I wonder if the markings varied based on the supplying vendor.
In this thread, my reply #9 shows the hose (04B LOS L35) that has been on the car since I bought it in 1980.
http://www.camaros.org/forum/index.php?topic=12817.0
The car has the original fuel pump so I believe this hose (SAE 100R6) to be original too.
Post by: 169INDY on November 26, 2018, 07:12:23 PM
Does, Pace Car Jeff Guy do these?, I think he has the Rad hose down right?
JIM
Post by: Danzo on December 01, 2018, 06:38:32 PM
This is what Jeff has.
Post by: z28z11 on December 01, 2018, 10:46:09 PM
Here's mine, from my 03D Z11. Kinda faint, dated 11/28/8. Not ribbed, but "textured" with the reinforcing plys noticeable -
James - yours is pristine compared to mine. Amazing construction (from the U.S. of A !) to last this long.
Post by: Danzo on December 02, 2018, 08:31:23 AM
Thanks Steve, do your letters and numbers measure roughly 3/16"?
This hose is from line to pump?
Anyone else have their original hoses?
Thanks, Doc.
Post by: z28z11 on December 02, 2018, 04:52:07 PM
Quote from: Danzo on December 02, 2018, 08:31:23 AM
Thanks, Doc.
Doc,
Yes, this is the frame line to pump hose, The "GM" seems a little larger than the balance of the markings, measures almost .250", the rest are right at 3/16" best I can scale them. The square is about the same as the GM logo -
I've noticed the reproductions have several additional markings that the original don't have. I replaced mine with Goodyear fuel lines (but I don't see concours judging in my Z11's future.
Post by: Pacecarjeff on December 04, 2018, 01:26:01 AM
Quote from: Danzo on December 01, 2018, 06:38:32 PM
Mine is generally what the Midyear Corvette guys wanted.  I just produced what an NCRS guy sent me a picture of.
I can make anything, so when we all figure out what the Camaro used - -just show me.  I would only take me a week to duplicate.
Post by: BULLITT65 on December 07, 2018, 01:29:41 PM
I hope someone can send you a sample of the gas line. I had to replace my original due to cracking.
Post by: Mike S on December 07, 2018, 03:09:40 PM
 If you have a picture and know what the line OD is then based on that reference you can get an accurate estimate of the font sizes and go to places like rubberstamp.com to get a stamp made up. That is what I did for my PTB stamps (repro's are too large) as well as upper and lower radiator hoses (repro's have wrong numeric fonts).
Post by: Danzo on December 09, 2018, 12:30:36 PM
So far we have two examples which go from Dec to April using the same format. If anyone has any example(s) please post it/them. Jeff, would you sell the stamp or a hose with the stamping on it? also need more examples to see how the date was spread out. Never heard back from Bill in Ohio.
Thanks.
Post by: Steve Shauger on December 09, 2018, 01:41:14 PM
My 9B of 68 L34 survivor had identical 5/16 hose that James pictured with GM and box. I've attached a 3/8 hose from a 4C Z28 survivor. I don't see a logo and have only wiped with WD 40.
Post by: BillOhio on December 09, 2018, 06:14:36 PM
I have had alot going on and never remembered to check my hose but good chance if others have gotten the non stock looking hose at heartbeat that is what mine is.  I am having hip surgery in the morning and the hose wont get looked at till spring now. Sorry I didnt get that done but guessing its not correct
Post by: Danzo on December 09, 2018, 07:10:33 PM
It's all good Bill. Best of luck with the surgery!
Post by: 68camaroz28 on December 09, 2018, 07:34:01 PM
Quote from: paceme on December 09, 2018, 01:41:14 PM
As Steve's I've looked at low mileage survivors and noticed zero in the way of any stenciled writing on the hose and the reason I suggested putting a hose on with nothing on it vs. the repro hoses offered for sale as correct.
