Camaro Research Group Discussion => General Discussion => Topic started by: camaroman1969 on June 18, 2018, 08:44:51 PM
Title: Bellhousing alignment procedure
Post by: camaroman1969 on June 18, 2018, 08:44:51 PM
Hello everyone....Question:  Does anyone here know the proper procedure on aligning a bellhousing???  We used a dial indicator, but everytime we would recheck the reading, they would "differ" from previous reading.  Used new dowel pins also.  Still no good.  Going to purchase some stock dowel pins and see if that helps.  Any assistance would be appreciated guys.  Thanks!
Title: Re: Bellhousing alignment procedure
Post by: william on June 18, 2018, 08:58:58 PM
http://www.camaros.org/bellhousings.shtml
Post by: HustleRussell on June 19, 2018, 03:00:38 PM
Make sure your indicator is not running out of travel.
And is in contact with bore the whole 360 degrees.
Also make sure any parts of the magnetic base are
not rubbing on the bell housing.
