My 67 doesn't have A/C.
About 20 years ago I broke the defroster lever in my dash heater control, a common problem.
Back then they didn't make a replacement repop, and I ended up fixing it with a tiny piece of metal, a couple of screws, and good ole JB weld.
Before I did the repair I tried to buy a used replacement control set, but the seller sent me a set with A/C controls. I ended up keeping it thinking I might add A/C someday and it would be nice to have.
Now I'm looking at it and I can't figure out how to confirm that it is even from a Camaro, more less specifically a 1967 as advertised back then.
Can anyone tell me about it based on the pictures? I don't see anything that looks like a date code, is there one or am I missing it?
Full size photos are at https://www.linkpro.net/piwigo/index.php/category/6 (https://www.linkpro.net/piwigo/index.php/category/6)
Thanks for any info.
More pictures of numbers
and one more
That's a mid 68 control.
Below is the 67 (top picture), and very early 68 / mid 68 (bottom picture).
More info HERE (http://www.camaros.org/forum/index.php?topic=8269.msg56576#msg56576).
I had some thoughts on this but nothing solid.
But I had a feeling that Ed would have answers for you. :)
Quote from: bertfam on June 16, 2018, 08:59:00 AM
Thanks Ed, So really these can be ID'd simply by looking at the face and there isn't anything significant about all the numbers inside. Good to know.
I have my original controls out of the car to replace the control cables and bezel, which is what got all this started.
I'm wondering if I should go ahead and replace the fan switch, do those go bad? I see they are available now.
You might get a kick out of my half-ass JB-Weld repair, that repair worked, but unfortunately I went a little crazy and epoxied the tabs that I broke getting the case apart.
Pictures https://www.linkpro.net/piwigo/index.php/category/7
