Camaro Research Group Discussion => General Discussion => Topic started by: 67jeffreyt on April 23, 2018, 07:31:39 PM
Title: My 67 SS RS camaro
Post by: 67jeffreyt on April 23, 2018, 07:31:39 PM
Factory AC car, four speed m20, 3.31 12 bolt posi. Numbers do not match on engine and transmission, it is a 1970 350 4 bolt main, forged crank, forged pistons, balanced.  Heads are 461 casting 2.02 with 7/16 screw in studs, guideplates, stainless roller rockers, hydraulic roller cam. Distributor is converted to XRI ingnition.  Car is factory deluxe interior. Factory body color was butternut yellow with black vinyl top
Title: Re: My 67 SS RS camaro
Post by: Kelley W King on April 24, 2018, 06:14:59 AM
Looks good. I see you have the vented oil fill and appears to be solid valve covers. Since the 70 block does not have the draft tube hole for ventilation how did you deal with that? Late models have the vent in the valve cover.
Post by: 67jeffreyt on April 24, 2018, 09:05:43 AM
That's a great question and I will show you.  I got the 67 intake for free so I felt it didn't hurt anything to drill it
Post by: 67jeffreyt on April 24, 2018, 09:09:45 AM
How it looks without air cleaner
Post by: 67jeffreyt on April 24, 2018, 09:32:37 AM
Without valve covers
Post by: 67jeffreyt on April 24, 2018, 09:35:14 AM
Without the intake
Post by: Kelley W King on April 25, 2018, 06:16:03 AM
Never seen it done that way before. Looks really good.  I remember back when I was in training to be a wrench twister I replaced my 66 long block with a 68 from the scrap yard and kept my MT valve covers with no holes. Took me a while to fiquire out why it blew oil out of the gaskets and oil fill when I turned it. Broke one of the MTs cutting breather holes.
Post by: HOGDADDY on April 26, 2018, 11:40:02 PM
Can you send me a bigger pic I can't see what you did here? Thanks.
Post by: 67jeffreyt on April 27, 2018, 09:01:29 AM
Intake was drilled and tapped to take vacuum from the lifter valley
