Camaro Research Group Discussion => General Discussion => Topic started by: go2fast on November 23, 2005, 06:08:49 PM
Title: Starter question
Post by: go2fast on November 23, 2005, 06:08:49 PM
I have a '68 that used to have a turbo 350. I'm replacing it with a muncie, but I'm having a starter problem. I have a 621 bellhousing with an 11" clutch on a 14" 168 tooth flywheel (same size at the old flex plate). Everything fits but the starter. It's not even close. The nose is too big for the bellhousing.  It's the original 327 with the offset starter bolt holes. Do I need a different starter? I thought all the 168 tooth starters with the offset holes where the same.
Title: Re: Starter question
Post by: 4myz on November 23, 2005, 07:49:15 PM
YOU NEED A STARTER THAT HAS THE CAST IRON REAR HOUSING
Post by: go2fast on November 23, 2005, 09:29:38 PM
Quote from: 4myz on November 23, 2005, 07:49:15 PM
What were they used on? How can I tell it's the right one?
