Camaro Research Group Discussion => General Discussion => Topic started by: Rich 5150 69 on October 25, 2017, 07:50:44 AM
Title: Smog equip or lack of ?
Post by: Rich 5150 69 on October 25, 2017, 07:50:44 AM
My `69 RS/SS is a Los build, sold in Calif....has no smog equipment what so ever, never had it on it that I can tell...had one guy look at the dash and said it was an AC car.....does the AC mean something..?
Title: Re: Smog equip or lack of ?
Post by: bertfam on October 25, 2017, 08:50:58 AM
No, ALL 1969 Camaros came with either the Air Injection Reactor (smog pump) or the Controlled Combustion System (CCS).
More info HERE (http://www.camaros.org/emissions.shtml).
Post by: ko-lek-tor on October 25, 2017, 12:19:51 PM
Automatic  350 car would not have smog.
AC= air conditioning...usually?
Post by: bertfam on October 25, 2017, 12:22:49 PM
QuoteAutomatic  350 car would not have smog.
ALL 1969 Camaros had smog equipment. It just depends on the engine/transmission combination as to what KIND of smog setup they had. Either AIR or CCS as shown in the link I posted above.
Post by: william on October 25, 2017, 12:36:48 PM
Small-block automatics had the CCS system; manual trans had the AIR pump.
All big blocks had the AIR pump.
A/C was not a factor.
Post by: Rich 5150 69 on October 26, 2017, 07:23:11 AM
Thanks guys ...leave it to the newbie to not look before asking....!  ::)  I prefer the CSS system for a cleaner look..
Post by: marriest on October 26, 2017, 04:32:29 PM
I have a 1969 Pace Car built in Norwood OH, 396 CID 325 HP. It was shipped to a dealer in St Leonard, PQ Canada per a General Motors of Canada Limited info sheet. It has 4 plugs in each exhaust manifold anyone explain why. It does not look like it had any emission equipment on it.
Post by: 1968RSZ28 on October 26, 2017, 05:05:28 PM
Quote from: marriest on October 26, 2017, 04:32:29 PM
In 1969, Canadian cars used the same emission controls as U.S. cars.  Someone removed the smog pump and related piping, then plugged the holes in the exhaust manifolds.  This was a common practice back in the day.
Post by: marriest on October 26, 2017, 05:09:04 PM
Thanks, so without smog equipment it is not an original?
Post by: 1968RSZ28 on October 26, 2017, 05:20:04 PM
Quote from: marriest on October 26, 2017, 05:09:04 PM
The car didn't leave Norwood without the smog equipment.
Post by: BULLITT65 on October 26, 2017, 10:59:06 PM
There are probably more cars out thee with the plugs in the manifolds than have the smog equipment. It got tossed by original owners pretty quickly. Some guys purchasing an original car would get lucky and the original owner may have just boxed it up.
Some of that original smog stuff sells for ridiculous money now, since it is scarce.
But, yes if you want the motor to appear original you would need to locate the smog. You can always remove the guts of the pump, and just have it for looks though ;)
Post by: Charley on October 28, 2017, 07:42:05 AM
Is 69 different than 68 in regards to smog equipment in Canada ? I know you could order smog delete in 68. A friend has a 68 L78 with 10K miles that shows smog delete on the paperwork and has the plugs in the manifolds.
Post by: Charley on October 28, 2017, 07:49:33 AM
This is the car with the smog delete
Post by: dutch on October 28, 2017, 09:35:55 AM
My Z'd has the same KD1 smog exemption noted in the G M Vintage Services documentation that I have - but again it is a '68 model.
Anyone know if this KD1 RPO was carried over to cars delivered into Canada into the '69 model year at all?
Post by: 1968RSZ28 on October 28, 2017, 09:48:28 AM
Quote from: dutch on October 28, 2017, 09:35:55 AM
KD1 (air injection reactor delete, export only) was only available in 1968.  It was not available in 1967 and 1969.
http://www.camaros.org/pdf/options.pdf
Post by: bertfam on October 28, 2017, 10:00:06 AM
Guys! Read the link I posted above. It has EVERYTHING you'd ever want to know about smog on these cars. Kurt spent a LOT of time compiling this information. Make use of it!!!
Post by: Pacecar on October 28, 2017, 03:34:51 PM
My car is also a Canadian car and was sold by the dealer without the smog. Holes plugged. Original owner, a woman, confirmed this.
