Camaro Research Group Discussion => Maintenance => Topic started by: BobH11 on July 17, 2017, 05:35:23 AM
Title: gauge cluster lighting
Post by: BobH11 on July 17, 2017, 05:35:23 AM
could someone tell me what this is. It seems plug in behind the oil pressure gauge.
Title: Re: gauge cluster lighting
Post by: KevinW on July 17, 2017, 06:10:23 AM
Bob, looks like the low fuel warning module.  Kevin
Post by: BobH11 on July 17, 2017, 06:23:54 AM
That's it ...Thanks Kevin
Post by: 68Zproject on July 17, 2017, 09:53:31 AM
I think it plugs into that empty hole between the light bulbs, but no bulb goes in it.
Post by: z28z11 on July 17, 2017, 04:59:13 PM
Quote from: 68Zproject on July 17, 2017, 09:53:31 AM
Correct. They always fall out of the hole at some point, apparently. Mine was loose in the bottom of th egauge pack when I took them out of the console - it's not a very tight fit. Understand this module was used in other applications that used a bulb in this socket ?
