Camaro Research Group Discussion => Originality => Topic started by: rod396 on June 26, 2017, 09:55:11 AM
Title: 68 Big Block Radiator Codes
Post by: rod396 on June 26, 2017, 09:55:11 AM
I am of the understanding that the 67-68 Big Block radiator code on the pass side tank for manual trans is "OL", and this is for a 4-row core (?) but I can't seem to find what the code would be for a 23-inch, 3-Row core, Big Block, manual trans.
Does anybody know what the correct code for the pass tank would be? Original/survivor examples.
Thank you.
Title: Re: 68 Big Block Radiator Codes
Post by: bcmiller on June 26, 2017, 09:59:51 AM
Have you looked at the tables here at this link below?
http://www.camaros.org/coolingsystems.shtml
Post by: ko-lek-tor on June 26, 2017, 08:44:51 PM
Has a 4 core ever been documented in a 68 manual trans? According to the highlighted data and my own knowledge, I haven't seen one.
Post by: rare396bronze on June 26, 2017, 09:42:07 PM
Yep 396 with a/c. My 68 with 4 speed has the 4 core.
Post by: KurtS on June 29, 2017, 10:34:47 PM
Quote from: rod396 on June 26, 2017, 09:55:11 AM
I am of the understanding that the 67-68 Big Block radiator code on the pass side tank for manual trans is "OL", and this is for a 4-row core (?)....
That's not what the radiator tank table in my article  shows. It  says big block and does not differentiate between the different cores.
Post by: rod396 on June 30, 2017, 03:23:31 PM
So it is only the tag that is affixed to the tank that specifies the core
The OL only denotes the larger tank itself
