Anyone have a ssource on oils splash shield and the rivets ? For small block intake. Thx
Which casting number? There are a lot of differences between them.
Cant help with the splash shield, but heres your rivets
http://www.ebay.com/itm/GM-NOS-10229247-3959544-4-55-81-Chevy-Camaro-CORVETTE-Manifold-Rivet-409-427/282254516935?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
This one if it's correct, comes with the rivets.
http://www.ebay.com/itm/Aluminum-intake-manifold-heat-shield-Corvette-LT1-Camaro-Z28-New-3758369-guard-/132233905533?hash=item1ec9c1457d:g:IfUAAOSwq1JZEiGR&vxp=mtr
Tha is for the info. Ed it's the 610 z intake? I thought they (small blocks) were all the same. I learn everyday on here :)
No, there are several. Mostly for cast iron, but even the aluminum have a few different ones.
Anyway, the 1967 & 1968 302 3917610 guard isn't listed in the P&A, but the 3932472 is (1969 302), and that one uses the 3758369 GUARD (http://www.ebay.com/itm/Aluminum-intake-manifold-heat-shield-Corvette-LT1-Camaro-Z28-New-3758369-guard-/132233905533?hash=item1ec9c1457d:g:IfUAAOSwq1JZEiGR&vxp=mtr). I would assume the 3917610 uses the same guard, but again, it's not listed so I can't say for sure. Maybe Jerry can verify this since he probably has a million of these manifolds stashed in his office!
In the eBay link Ed provided above, the seller (ggordog) states in the listing description...
"This will fit all small block Winters casted Chevy aluminum manifolds from 1962 on."
