Camaro Research Group Discussion => General Discussion => Topic started by: jim28607 on April 18, 2017, 02:47:11 PM
Title: Shifter adjustment Help
Post by: jim28607 on April 18, 2017, 02:47:11 PM
Hello,
I need your advice ,
When I got my car a BB 69 RS/SS non numbers
Car, it had a Blatantly wrong shifter ....
So I decided to buy a correct rebuilt
3138 shifter assembly, then I got a
supposedly correct aftermarket BB Linkage with
Mounting plate set up.
Everything installed and shifts great ,
except when I go into reverse , it seems that
The shifter travel is to long , pulling the reverse
Lever to a full 90 degrees from the neutral"down" position
Then that angle is such that I can't shift out of reverse.
Thanks for any help you can offer.
Title: Re: Shifter adjustment Help
Post by: HawkX66 on April 19, 2017, 07:57:44 AM
Quote from: jim28607 on April 18, 2017, 02:47:11 PM
Hello,
You should be able to screw the rod into the shifter adjustment nub further to shorten the travel. That's part of the basic set up procedure.
Post by: JoeC on April 19, 2017, 09:16:35 AM
do you have the rod in the correct hole on the trans reverse lever ?
there are two holes and the lower hole is for the trans lockout rod
Post by: jim28607 on April 20, 2017, 04:26:03 AM
Quote from: JoeC on April 19, 2017, 09:16:35 AM
Quote from: HawkX66 on April 19, 2017, 07:57:44 AM
Hello,
Thanks , I am certainly no expert on this ,
but with the shifter in the neutral position,
And all three transmission shift levers in the down,
Neutral position , there is no guess work as
To rod adjustment length?
Post by: jdv69z on April 20, 2017, 08:07:20 AM
This is a Hurst, correct? When making adjustments, do you have the neutral alignment rod installed? I think it's just a 1/4" rod that lines up the shifter levers to neutral with the trans. Is it possible you have one of the arms upside down? I just went through this with a competition plus. I was able to install the rods upside down and get to work.......sort of. It obviously wasn't right, but I was able to actually drive it that way. 1st was where 2nd should be and vice versa. I finally got it worked out. Do have the Hurst assembly diagram? You can get it online if you need it.
Post by: JoeC on April 22, 2017, 10:00:12 AM
rod length  will not change the travel length
the length of the trans lever will
could be something wrong inside your shifter
hard to say but I have seen broken levers inside the shifter
can you post pics showing the problem ?
Post by: jim28607 on May 19, 2017, 05:12:37 AM
At last I figured it out !!!! :-[
The AIM shows the reverse lever at the
6 o'clock  position, but it should actually
be at the 7 o'clock , I had the lever on backwards
Flipped it over and all works like a charm!!!
Thanks for all your replies.
