Camaro Research Group Discussion => General Discussion => Topic started by: 67jeffreyt on April 03, 2017, 03:32:32 PM
Title: 67 front speaker dimensions
Post by: 67jeffreyt on April 03, 2017, 03:32:32 PM
I've googled and searched,. What size speaker is the factory front speaker, I've seen several different size replacements,. Also provide recommendations, my car is factory ac.  Any information is appreciated
Title: Re: 67 front speaker dimensions
Post by: 67 nut on April 04, 2017, 09:16:55 PM
The front speaker is 4" x 10". Factory speaker resistance is 10 ohms.  If using your original GM radio, make sure your replacement speaker is 10 ohms.  If using current model radios, a 4 ohm speaker will be needed.  The factory A/C cars use a smaller speaker thickness, usually resulting in a shallower depth magnet which equals less power handling capabilities.
Post by: Petes L48 on April 04, 2017, 11:21:04 PM
Quote from: 67 nut on April 04, 2017, 09:16:55 PM
I don't see a separate speaker listed for A/C cars in the AIM under UPCs C60 or the U series.  Where did you see a thinner speaker was used?
Post by: 67 nut on April 04, 2017, 11:41:31 PM
I should have been a little more specific.  Thanks for pointing that out.  The factory speakers were the same for A/C or non A/C cars (10 ohm).  The AFTERMARKET replacement speakers (4 ohm) have much larger magnets to handle today's much more powerful radios.  The AFTERMARKET a/c speakers (also 4 ohm) have smaller magnets as to not physically interfere with the a/c control unit, making them less able to handle as much power.
Post by: Petes L48 on April 04, 2017, 11:44:19 PM
Got it, thanks.
Post by: 67jeffreyt on April 05, 2017, 04:21:33 PM
Ok awesome, thank you, my stereo is not factory,but I only currently have the two rear 6x9s. Just wanted to get replacement but didn't know which size to get, other than it needs to be for ac car
