hello does anyone know for sure on 1968 unrestored car if the front wheel well molding goes all the way down the facing the door or is cut short to the factory molding. molding is on angle going down . also the rear molding facing the door does it go all the way down or is cut short to meet factory molding
thx
You have already asked this question and got an answer..... ALL 1968 RS cars wheel well trim stopped at the rocker molding..
http://www.camaros.org/forum/index.php?topic=14855.msg137066#msg137066 (http://www.camaros.org/forum/index.php?topic=14855.msg137066#msg137066)
i didnt see the reply would you know if its straight or on angle with the molding
thx
hi you are probably right i just looked at around 25 cars including ebay google images and 20 of them
have the molding all the way down do you own a unrestored rs ss 1968 camaro because im not going to cut my original
molding that i purchased directly from chevy and its for a rs ss camaro and it is the long one the back is shorter
and goes only to molding this is why asked
thx
You'd be lucky to find a 68 RS WW molding through a Chevrolet dealer these days. Even standard moldings are scarce, but that's what they'd sell you. It's up to you to cut them to fit an RS.
i know i got lucky i found 2. I still cant find the rear ones i bought from summit the whole set all 4 and the rear come
cut short already but the front come long just like the nos ones i have. Isnt that funny i even have a diagram where to cut them and still not sure even with the repro ones. Iknow you said they come short i want to see original car with original molding im anal that
way.
thx
heres the template for the cut but im not sure yet what to do
In 1968 there were two different moldings used 9785880 & 9785881 without RS package. 3928529 & 3928530 with RS package was cut shorter for the three piece rocker moldings. Get a book called the 67-67 Camaro reference book that shows some original photos of the RS cars back then. Great book to read. So yes you will need to cut the molding that have 9785880 & 9785881. Hope this helps
thank you im going to check it out
Quote from: lilfighta on January 24, 2017, 06:20:13 PM
It's probably best to partially install the molding, then mark it right where the point on the end of the 3 piece lower molding intersects, then use a straight edge to mark the cut line as in the diagram. Then install and drill another hole. I used a fine tooth hacksaw and file. Being aluminum, they cut like butter...
Hi Garth you are right and i did that although i didnt cut the molding no balls as of yet. Funny thing is why i didnt cut it
is because the moldings on right and left had holes for screws in 2 different places at the end and these are both nos from chevy dealer
the aftermarket ones are in the same place i think i will put aftermarket ones on and do exactly as you said. Did you happen to cut them on the angle of the molding or just cut them straight across
Thx Garth
They were cut straight across from the factory as shown on your template. I did kinda custom cut them for a better fit as I just think it looks better. Mine were NOS also, purchased in '90. The parts guy said RS were NLA and just to cut the standard !
This is about the best pic I have, off hand...
(http://i418.photobucket.com/albums/pp266/garfieldsmaro/rearmeat3_zpsejbym1qh.jpg)
wow looks great garth thx for that photo
would you happen to have one of front
thx
I'll see if I can get one in the next few days...give ya time to get your courage up ! ;)
lol your funny guy
Hey guy, if you want it to look factory original, you're gonna have to keep searching as I'm not much help. I've seen pics of what I thought were original, but danged if I can find them now ! I'm pretty certain they were cut straight and there's usually a gap between the lower molding, but not exactly sure where it was cut at. Surely there are folks around here with a 68 RS "survivor".... maybe they'll chime in eventually.
Anyway, this is how I did it. It's more of an angle cut, then filed trying to match the contour of the lower molding.
LF
(http://i418.photobucket.com/albums/pp266/garfieldsmaro/RSmolding1_zpsqxuspn3j.jpg)
Nice job i figure if I do it ill do it your way on angle it matches nice
