Camaro Research Group Discussion => General Discussion => Topic started by: jim28607 on October 24, 2016, 06:49:27 PM
Title: Reverse Lights
Post by: jim28607 on October 24, 2016, 06:49:27 PM
I noticed that the reverse lights on my recently purchased 69 rs/ss, did not work, did a little investigating, found the switch was unplugged, made the connection and the lights stay on all of the time, when the key is on, regardless of what gear the trans is in, why would my reverse lights stay on all of the time?
Thanks for Your Help!
Title: Re: Reverse Lights
Post by: BillOhio on October 24, 2016, 07:11:51 PM
Does it have headers?
Post by: jim28607 on October 24, 2016, 07:16:15 PM
No headers
Post by: JKZ27 on October 24, 2016, 07:18:05 PM
Jim, is manual or auto? I cant remember.
Post by: jim28607 on October 24, 2016, 07:35:37 PM
Oops my fault I didn't post, Manual Transmission
Post by: william on October 24, 2016, 07:51:27 PM
Lower lock rod may be missing. Runs from the reverse lever on the trans to the swivel on the frame. When shifting to reverse it rotates the column, activating the switch.
With the lights on, grasp the lower collar on the column and give it a 1/4 turn or so. If the lights go out, it's missing the rod. Sometimes the upper rod is also missing.
Post by: Z28Project on October 24, 2016, 08:41:50 PM
Yes, it wasn't uncommon to chuck that whole system back in the day, and then try to remember to rotate the column by hand to turn the BU lights off while driving. :)
Post by: jim28607 on October 24, 2016, 10:27:42 PM
Quote from: william on October 24, 2016, 07:51:27 PM
Interesting, Thank You Very Much!! I will Check that out.
Post by: alewis422 on February 09, 2017, 08:30:25 PM
I have a '67 SS and the reverse lights stay on when the key is on accessory or when the car is running regardless of the gear it is in.
I have both manuals, but I'm having a hard time tracking down where the switch might be.
It's a manual with the 4 speed Muncie transmission.
Any ideas?
Thanks!
Post by: rare396bronze on February 09, 2017, 08:40:33 PM
67-68  is mounted on the driver's side of the transmission.
Post by: 1968RSZ28 on February 09, 2017, 10:19:23 PM
Quote from: rare396bronze on February 09, 2017, 08:40:33 PM
Yup, so simple and reliable! :)
Post by: alewis422 on February 10, 2017, 07:17:46 AM
Ha, yea...reliable  ;)
So...is there a way/is it worth it to test that switch? Or should I just buy a replacement? I'm assuming its just the device with a black and green wire that plugs into the drivers side of the transmission that you mentioned?
Thanks!
Post by: z28z11 on February 10, 2017, 08:42:03 PM
Quote from: alewis422 on February 10, 2017, 07:17:46 AM
Thanks!
The '68 switch mounts on a bracket that bolts onto the side cover, has a link arm to the reverse arm on the transmission that actuates the switch when the shifter is placed in reverse; you can simply drop the link and move the switch back and forth to test the action if you can get under the car (or preferably get it up on a lift).
The '69 switch mounts on top of the steering column under the dash, actuated by the internal sleeve in the column which is in turn actuated by the back drive rod/ bell crank that links with the reverse arm on the trans. My original was missing when I bought my Z in '73, the steering column back drive arm was wired up to keep it from actuating the switch and leaving the lights on all the time. You could usually tell when a car had been fitted with headers from a mile away and going away - reverse lights would be on all the time because a lot of people didn't go to the trouble of securing the column arm, allowing it to drop and actuate the switch.
The good ole days -
Post by: ssl78 on February 11, 2017, 07:05:36 PM
On 67 and 68 there is a adjustment where the switch mounts to the bracket
