Whadaya Think? ???
http://hickory.craigslist.org/pts/5775541135.html
At 30K I think he's going to own that engine forever..
Or longer than forever, at that price. :)
No proof in any of the pics to verify what he says it is.
So is that intake manifold gouged out to clear the carb secondary throttle plate?
Yes. Edelbrock ended up making a manifold with the notch already in it for the 3 bbl. when it was popular.
Yes, for the 3 barrel carb. It's an old racers trick used until the open plenum intakes were more common (even for 4 barrel carbs).
If you run across one that is uncut - do NOT cut it!
My 1967 Corvette has the original engine and it is a 351 block but is only a 390 hp did the 351 block have a lot of uses? thanks Darrell
The 3904351 block was used for Full Size Chevrolet (Impala), Corvette and Warranty/Service. 4 bolt main for 430 and 435 hp, and some Warranty/Service.
Thanks Bryon, I thought the 351 block was a Corvette only block I learn something new on this site every day
