Camaro Research Group Discussion => Restoration => Topic started by: Buck on September 01, 2016, 04:23:49 PM
Title: Oil Pump Identification / 69 DZ302
Post by: Buck on September 01, 2016, 04:23:49 PM
I'm trying to Identify this oil pump out of my 69 DZ302
Title: Re: Oil Pump Identification / 69 DZ302
Post by: ko-lek-tor on September 01, 2016, 06:22:46 PM
Aftermarket Melling High Volume M99HVS based on your tag https://www.summitracing.com/parts/mel-m99hvs
Post by: bcmiller on September 02, 2016, 10:43:50 AM
I am pretty sure the 302s just used a standard oil pump, but they had a better/heavier spring in them to get higher pressure.
Post by: Buck on September 02, 2016, 12:58:38 PM
Thanks Guy's, I know the motor was built for performance, The upgrade history on this motor spans from the early 70's to the late 90's. I'm finding all kinds of surprises as I tear it down. The engine was made to run at high RPMs so it would make sense he would of installed a Melling pump. Thanks Ko-Lek-tor !! That's one more part identified  :)
