Looking for a 1/4 x 3/4 bolt with rbw head markings. The number listed above is from AMK but of course they have a $30.00 minimum. Anyone have another source? Thanks in advance.
What's the GM number -or- AMK page number?
I'll check my box of bolts.
I found it. It looks like a valve cover bolt? I have one in my hand and though it has RBW it doesn't have the 3 lines on the face. I've seen many valve cover bolts with and without the 3 lines. Do you need the lines?Also, the zinc plating is worn from age.
Mike, thanks for the very generous offer. I am looking for a complete set. Talked to Camaro Specialties today and they think they can help.
There is a guy that sells original hardware on The Super Car Registry board ...in the classified section.....
Are they valve cover bolts?If so I have a complete set that I bought from Heartbeat City that I did not use.They have the RBW markings with no lines.It also comes with the valve cover holdowns.The part # is EGB-1938.
I believe those bolts are 1/4 x 1/2"
If you are looking for some original bolts or replacements, it would help if you told us the original application.
1969 396 325hp. I am running thicker valve cover gaskets hence the need for the 3/4" length vs 1/2".
Thanks, Doc.
Why thicker gaskets?
Higher quality gasket.
