Orphans - documentation or VIN-stamped drivetrains - in search of the original cars => 1968 - Orphans => Topic started by: 1968RSZ28 on May 23, 2016, 11:11:10 AM
Title: 8N469697 - Z28 Engine Block
Post by: 1968RSZ28 on May 23, 2016, 11:11:10 AM
Your 302cid/290hp Z28 engine block is on eBay...
Engine pad is stamped: 18N469697  V0708MO
Block casting number: 3914678
Full VIN: 124378N469697
Seller id: lebeau4parts
Seller location: Rogue River, OR
http://www.ebay.com/itm/291771069888?item=291771069888&viewitem=&vxp=mtr
Seller description...
"1968 MO 302 CHEVY Z28 BLOCK, THIS IS THE REAL DEAL.  STANDARD BORE.  ONLY ONE PROBLEM, IT HAD 3 CRACKED MAIN BOLT HOLES ON THE MAIN WEBS.  I THINK IT COULD BE FIXED WITH HELI COILS AND MAIN STUDS AND HAVE ZERO ISSUES WITH IT.  I HAVE BEEN KEEPING THIS BLOCK FOR OVER 15 YEARS BECAUSE ITS A REAL ENGINE.  STAMP PAD READS V0708MO SERIAL NUMBER OF THE CAMARO IS 18N469697.  IF THIS IS YOUR Z I HAVE YOUR ORIGINAL BLOCK.  THIS IS FOR THE BLOCK ONLY. CAN BUILD AND DYNO FOR EXTRA.  PLEASE ASK ANY QUESTIONS. THANKS"
