Camaro Research Group Discussion => Restoration => Topic started by: C5Phil on April 30, 2016, 03:12:16 PM
Title: 69 coupe dual exhaust reinforcement plate-missing?
Post by: C5Phil on April 30, 2016, 03:12:16 PM
I have an early build LOS coupe (09A) that shows all signs of originally being an "SS"- EXCEPT it does not have the reinforcement plate for dual exhaust- Is it possible that early builds did not receive the plate until production had already started?
Title: Re: 69 coupe dual exhaust reinforcement plate-missing?
Post by: 69Z28-RS on April 30, 2016, 04:55:19 PM
The existence of that plate is one of the primary  'identification' points for determining if a car was an original dual exhaust model (ie. SS, Z28, etc)...  What other means do you have to verify it was originally an SS model?
Post by: C5Phil on May 01, 2016, 06:38:47 AM
I have no other info. except that it has a BL coded 12 bolt rear end (currently a 3:55 posi) but that code was for a 3:07 open rear end.
My guess was it might be an LM1- but no proof. Thanks for taking the time to reply.
Post by: KurtS on May 01, 2016, 09:25:46 PM
Phil,
Same people answer both forums, btw. :)
