Camaro Research Group Discussion => Decoding/Numbers => Topic started by: Camarocards on March 29, 2016, 07:32:10 AM
Title: '69 Steering Column Broadcast codes CB and KB
Post by: Camarocards on March 29, 2016, 07:32:10 AM
I posted the below question on the Team Camaro site but got no response. Perhaps someone here knows the answer.
Does anyone know the difference between steering column broadcast codes CB and KB? This would be for a '69 tilt column, floor shift with assembly number 7808154.
Bob
Title: Re: '69 Steering Column Broadcast codes CB and KB
Post by: x66 714 on July 08, 2018, 01:42:02 PM
My 69 has the same column. Column date is A709S. Assm date on the car is 08/28/1969. Was the CB code used for later 69s?
Thank you, Joe
Post by: Bigfish45 on July 09, 2018, 11:18:58 PM
Where is the date code on 69 columns?
Post by: ZLP955 on July 09, 2018, 11:53:07 PM
Quote from: bigfish45 on July 09, 2018, 11:18:58 PM
Here's a link to Darrell(69 Zee)'s thread on his X77 find, showing stamped codes on the column:
http://www.camaros.org/forum/index.php?topic=12511.msg106458#msg106458
Post by: x66 714 on July 10, 2018, 08:02:05 AM
On mine it was on the LH side of the column almost in line with the arm of the brake pedal....Joe
Post by: KurtS on July 17, 2018, 10:26:19 PM
Neither CB or KB appear on broadcast sheets.
KB is a floor shift w/ tilt.
