I can not find the part numbers for the horn contact cam w/tilt and the cap mount with horn contact tab. I looked all over the 68 AIM and couldn't find much on the N34. So, let me ask a few questions...
The parts vendors say the parts are the same for 68 and 69, Bull. The 9751046 horn cap mount for the 69 hub 3937896, has a longer tab on it to make up for the hub being shorter, doesn't it?
I need the correct pn# for the horn cap mount and the horn contact cam w/tilt for the 68 3930062 hub? I had thought the 68 cap mount had a shorter tab on it for the deeper hub. If any other parts are different for the internal parts from 68 to 69, I would need those numbers also.
Bryan
Bryan check this site under "Interiors" then go down to steering wheel usage, I think you'll find what your looking for.
Thanks Vince, I checked this section before I posted. All I saw in this section was the correct hub 3930062 and the series of horn caps 3901313 and 3923667, and then 3945461 for 69. I was looking for the 1968 CORRECT horn cap MOUNT with correct length tab for the 3930062 hub and the CORRECT horn CONTACT CAM for tilt wheel. This is the round black plastic contraption with the stem that makes contact, and used with tilt. These parts, I did not see listed on the site, AND I did not find a N34 section in the 68 AIM. Please help, I can not find these part numbers.
Bryan
