Camaro Research Group Discussion => Restoration => Topic started by: 69z27z87 on January 20, 2016, 12:52:44 PM
Title: now the front springs....
Post by: 69z27z87 on January 20, 2016, 12:52:44 PM
15 years ago I replaced the front springs in my 69 big blockwith new ones from Eaton because I thought I had an issue... turns out I did not but fortunately I did save the old one. Now that the full resto is underway, I'd like to re-finish and re-install the originals.
I checked the old ones and they are identical in height. Are there any references out there for the correct unloaded height (length) for the front coil springs so I can check if there is any loss in height to date?
I believe the springs were originally just natural metal finish... I am going to blast and powdercoat (Eastwood). Any recommendations on what color would work best?
All SS cars got the F41 "Heavy Duty Suspension" in 1969 right?
Title: Re: now the front springs....
Post by: Steve Shauger on January 20, 2016, 01:17:14 PM
no F40 was standard.
Post by: 69z27z87 on January 20, 2016, 09:28:09 PM
According to Jerry's data book, all big block SS cars got the "heavy duty suspension" setup..... I believe that means F40....as F41 was "special duty suspension" on some rpo lists. Can someone confirm??? Still want the right code for the springs....
Any answers on the best color to use?
Post by: 69Z28-RS on January 20, 2016, 10:03:10 PM
Quote from: 69z27z87 on January 20, 2016, 09:28:09 PM
k
Coil spring color was *natural*...  raw spring steel...
What was the code on the tag on your springs??   If it happened to be EY I could give you the dimensions.. :)
Post by: 69z27z87 on January 20, 2016, 10:22:19 PM
Tag long gone.... I figured out it was HA or EA depending on F40 or 41.
Now what color powder coat is closest to "natural".... That's the trick..
Post by: 69Z28-RS on January 20, 2016, 11:13:22 PM
When I disassembled my front suspension for a refurbishment, I found one of my EY springs had a broken coil (at the bottom), which I didn't know.  so I sent the good EY coil to 'Coil Spring Specialties and spent several months and many phone calls and tests to have them 'duplicate the spring' in all respects (no of coils, dia of coil spring, unloaded height, etc) and with the same or very close spring rate).  PIctures are the two new ones on either side of the original EY spring.  I think you can get an idea of the proper color of the raw spring steel as new from this photo.  Of course, the raw metal would surface rust fairly quickly so I coated my new ones with satin clear to preserve the raw color a bit longer.
Post by: buenymayor on January 21, 2016, 05:12:51 AM
I'd get a professional opinion about powder coating the springs I had mine powder coated and baking them seems to have "relaxed" them some and my front end sits lower than it did. Maybe baking them didn't have an affect on them, but I've always wondered. Either way. they will be getting changes this winter.
Post by: 69z27z87 on January 21, 2016, 08:41:55 AM
I checked around and Eaton Detroit Spring says the magic number is 400F when spring steel begins to soften. At what temp do we powdercoat? 400F....
Funny, I thought Eaton powdercoated their springs...?... Guess I will avoid that with the original springs.
Any other thoughts on standard vs heavy duty stock suspension on the big block SS cars? production numbers lead me to believe it should be the "standard" suspension.... but what is "heavy duty" F40 or F41?
Post by: HawkX66 on January 21, 2016, 10:19:40 AM
Have you seen this? It explains which springs pretty well.
http://www.camaros.org/images/pages/chassis/69_spring_chart.pdf
Post by: 69Z28-RS on January 21, 2016, 10:28:30 AM
Quote from: 69z27z87 on January 21, 2016, 08:41:55 AM
I think most aftermarket spring companies 'coat' their springs so they will be nice and pretty for the customer; Coil Spring Specialties typically coats their custom springs as well, but I asked them not to do so in my case, since I was attempting to duplicate the original EY factory springs.
Depends on what you want to do... :)
Post by: BillOhio on January 21, 2016, 10:57:14 AM
David Pozzis website has some good info on springs and which Moog ones cross over.
You need to look under 1st gen info
Post by: 69z27z87 on January 21, 2016, 11:23:15 AM
I already worked through the spring data on CRG and I did review the Pozzi info.... I know my additional weight but is it more likely I have the "standard" spring or the "Heavy Duty" spring as shown in the spring tables. Jerry's data book states all big block SS cars have "Heavy Duty" suspensions..... So what tag should I use...304lbs overage on the front.
Given what I have found.. I would like to clean up the original springs... but I have concerns on ground glass blasting the springs... then paint.
Post by: 69Z28-RS on January 21, 2016, 12:35:09 PM
Quote from: 69z27z87 on January 21, 2016, 11:23:15 AM
What are your concerns?   If I hadn't had a broken spring, I'd definitely have taken that approach with my original coils; glass beading will not harm the springs in any way (except for removing corrosion), and painting is probably 85% as durable as powder coating (and you have more control over the color/coating, and at less expense)...
Post by: 69z27z87 on January 21, 2016, 12:53:49 PM
we say "glass beading" but the stronger grits are really ground glass with sharper edges... My blast cabinet has 40-70 grit glass in it. It removes rust and leaves a slight texture. Some lesser grit glass almost polishes the surface with less material removal....
Post by: Edgemontvillage on February 26, 2016, 02:30:29 PM
I needed a set of replacement springs for my 1969 RS Z project so I contacted EATON Detroit Spring who I've dealt with in the past with good results. When I tried to place an order for a set of EY springs EDS stated that all their springs are now shipped with a powder coat finish in either grey or black (you don't get a choice). I asked them to ship me a set in unfinished / uncoated steel however they refused and wouldn't accept a custom order either. I noted that a fellow CRG member Gary W. (69Z28-RS) had done a lot of work (painstaking actually) specing a replacement set of springs for his 69 RS Z, which, coincidentally is almost exactly the same as mine, so I contacted Gary who graciously provided me all the information I needed to order the same set from Coil Springs Specialities in St Mary's KS.  CSS was very accommodating and shipped my (custom) order in a couple of weeks at about the same price as EDS charges for a stock order. The coil springs arrived last week and they look terrific. The shipping box was a bit flimsy however the springs  arrived undamaged. The proof will be in the fit and stance however I'm impressed so far.
(http://i1187.photobucket.com/albums/z396/edgemontvillage/Camaro%20Parts%20References/image_zpsqo83gz8d.jpeg)
Post by: 68camaroz28 on February 26, 2016, 04:30:40 PM
Good info to know Lloyd. And glad Gary both found a source and communicated as well.
Post by: 69Z28-RS on February 26, 2016, 04:38:37 PM
Although one of my springs had the bottom coil broken off, they each had the factory 'EY' blue tags on them, so I knew exactly what my car came with from the factory (also verified by the tabular data found in the factory manuals).  I purchased two different sets of OTS springs (as suggested by people here and from TC) and found that neither of them matched the physical specs (no of coils, coil thickness, unloaded height, etc) of the factory springs.  I posted my questions and concerns here, and Steve Stauger was kind enough to suggest to me to contact Coil Spring Specialties, which I did.  I sent them my good original spring; they tested it.. and I also relayed to them that I wanted to physical specs to match as well as the spring rates.   Over a few months, we finally agreed on the specs/rates and they shipped them to me.   Mine are installed, but all of my front end sheet metal is not yet installed, so I cannot testify about the static height in the completed car.  I think Lloyd had CSS build his set to match what they did with mine; hopefully both my car and his sit at the correct height and ride consistent with a new Z28/RS when we get them completed..  :)
Post by: 69Z28-RS on February 26, 2016, 05:23:22 PM
Lloyd, did you pass along to Coil Spring Specialties the specs I provided to you (which I'd given to them)???   I was curious, and counted the number of coils in yours and compared to mine.  (See photos below)...  Yours seems to have an additional coil (9) versus the (eight) in mine....  and based purely on visual appearance, your coil wire diameter seems larger??  What about unloaded length?   I think we should compare specs on these if you are willing, because I am not sure they made yours to match the ones they made me??  Note:  The specs agreed between Kevin and myself were:  Use .610" wire diameter,  8.125 Total coil, Inside Diameter will be 3.675", Free Length will be 15.00" +/- , and  Load Rate will be 370#/in.   How close to these specs did you and CSC agree to??
Post by: Edgemontvillage on February 26, 2016, 10:49:28 PM
Gary, according to Kevin, he pulled your actual order and re-ran it. I am curious how there is an additional coil, will talk to him on Monday.
Post by: Mike S on February 26, 2016, 11:01:49 PM
  When I see coil springs I shiver. I don't know what you are planning to use as a compressor but I highly do not recommend the type that hook inside like monkey arms. I've used that type and during compression the spring violently unwound. This has happened twice in the same day to boot. I recommend the OTC 7045B spring compressor. It costs a little more but well worth it for safety as well as piece of mind when handling them while compressed.
I'm just saying....
Post by: 69Z28-RS on February 26, 2016, 11:19:33 PM
Yes, coil springs can be dangerous.   I recall seeing/hearing one come out violently once when I was working in the Keesler AFB hobby shop (probably someone who didn't know any better).  The shop manager (a retired Master Sergeant) got all worked up and in the face of the young airman who was working on it.   At that time, the sergeant/manager said to always run a safety device (chain) thru the spring and around the frame - ends of the chain bolted together) to restrain a coil that wanted to leave before you were ready for it.. :)    I've always followed that advice, and only one time was the chain really necessary.. but it's a good precaution...
I moved/re-installed my Z28 springs (removing the originals, installing the replacements) without a compressor.  I always run a length of chain thru the spring and thru the A-arm or around the frame when doing either of these task, because what you say is true (they CAN be very dangerous).. but in the case of removing the EY's and installing the replacements (in my case) there was little energy left by the time I'd lowered the lower control arm.. and I was able to get the new ones in place and put a floor jack underneath to install the replacements (although I did have to set my engine/trans back into place in order to get the ball joints reconnected.  (the engine was installed when I removed the springs, but not installed when I first began the front end rebuild with the new parts)...
Gary
Post by: Mike S on February 26, 2016, 11:27:31 PM
 What I like about the OTC 7045B design is you will not mar any chassis paint and chains are not really needed.
Its design prevents it from unwinding.
Post by: firstgenaddict on February 28, 2016, 04:58:14 PM
The easiest way I have found is to compress the spring to the lower A Arm then drop it in, 2 through bolts and lower balljoint.... release the compressor... voila!
Post by: Edgemontvillage on February 28, 2016, 11:09:05 PM
Quote from: Mike S on February 26, 2016, 11:01:49 PM
I'm just saying....
I've worked on lots of coil springs over the years and bar-none its the job I enjoy the least.  I make a point of using quality tools and a safety chain.
Post by: 68camaroz28 on February 29, 2016, 06:13:56 AM
Quote from: Edgemontvillage on February 28, 2016, 11:09:05 PM
I'm just saying....
Do need now but will keep James suggestion in mind! Lloyd, could not agree more that the coil spring assembly is nothing I look forward to and hopefully the 68 will be the last one I do. Let us know how you make out with the differences in your coil springs vs. Gary's.
Post by: Hans L on March 01, 2016, 03:25:27 PM
I'm just saying....
Totally agree.  I bought one of these from Rick's and made a scary job quite safe and easy:   http://www.rickscamaros.com/coil-spring-compressor-1955-1972.html
