Camaro Research Group Discussion => Maintenance => Topic started by: xdrive on December 31, 2015, 05:57:12 AM
Title: Spark plug for L48 engine
Post by: xdrive on December 31, 2015, 05:57:12 AM
Hello,
what are the correct spark plugs for my 1967 Camaro RS/SS 350 with the L48 engine (295HP)?
Thanks!
Title: Re: Spark plug for L48 engine
Post by: lakeholme on December 31, 2015, 10:22:22 AM
67 Service Manual in Tune Up Chart for 350/295 says
Standard - AC 44
Cold - AC 43
GAP is .035
Post by: JohnZ on January 01, 2016, 10:20:50 AM
Quote from: xdrive on December 31, 2015, 05:57:12 AM
Hello,
Thanks!
Do you have your owner's manual? It has lots of interesting detail, and doesn't take long to run through it.
Post by: xdrive on January 02, 2016, 09:22:31 AM
Thanks for the Info. Unfortunately I dont have an owner manual for my car. I did find the information in a service manual in the net but the AC 44 are hard to find here in Europe and I was thinking that there are some replaceables out there in the market. I found somewhere that AC Delco R44XLS may fit but not sure.
Post by: cook_dw on January 02, 2016, 09:47:25 AM
http://www.sparkplug-crossreference.com/convert/ac_delco/R44 (http://www.sparkplug-crossreference.com/convert/ac_delco/R44)
Example:
R45TS
R = Resistor
4 = Thread Size (14mm)
5 = Heat Range (0-9)
C = Copper Core
E = Special Design Electrode, Extended Tip
L = Long Reach
M = Special Design Electrode
S = Extended Tip
T = Tapered Seat Shell Design
X = Wide Gap
Z = Special Gap
6 = 0.060" gap
8 = 0.080" gap
