Camaro Research Group Discussion => Originality => Topic started by: abiddle on October 16, 2015, 11:25:03 AM
Title: firewall chalk - how did this look originally
Post by: abiddle on October 16, 2015, 11:25:03 AM
How does this look original, any examples? Is this a crayon and is it pre-paint? Or was this post-paint and someone has just rubbed it clean? I don't know what to think about this. Actually it took me all these years to figure out it said "RED". Duh.
Title: Re: firewall chalk - how did this look originally
Post by: william on October 16, 2015, 07:11:05 PM
During body fab Fisher Body workers wrote certain codes/notes on the firewall with grease pencil prior to any paint being applied. It stained the metal and is visible if the car is media blasted. Firewall blackout was applied after the car was painted. Paint doesn't adhere well to grease pencil and over time the writing becomes visible. Would have been no reason to write "RED" or anything else across the firewall of a body that was already built and painted.
It is not unusual to see a build sequence number written inside the lower grille panel. Possibly done to ease matching the body with the front sheet metal assembly. I have a vintage road test photo of a Nickey/Bill Thomas 427 '68 Camaro and there is definitely something on the firewall behind the engine; appears to be 48 E. Could have been SOP to write it there also and later wipe it off.
Also, '69 COPO Camaros often have '427' written inside the front fender extensions.
Post by: abiddle on October 16, 2015, 07:23:54 PM
I didn't think much about this until I saw this pic Chick's Z\28 survivor thread.
http://s192.photobucket.com/user/1-2-b-67L89/media/Survivor%20Camaros/100_9309_zpsabd7c1cb.jpg.html
Post by: Stingr69 on October 18, 2015, 10:15:19 AM
Mine says "RGRN" for Rally Green.  Sorry I do not have pix.
Post by: BillOhio on October 18, 2015, 04:42:19 PM
I thought I did this earlier but doesn't seem to be here. My burgandy car had MAR and several other things under the paint. N10 dual exhaust was easy to see. This is after soda blasting.
Post by: NoYenko on October 25, 2015, 08:33:54 AM
My firewall had "BBLU" written on it. Guessing it stood for big block & Le Mans blue??
Post by: william on October 25, 2015, 10:56:06 AM
More likely bright blue.
Post by: BULLITT65 on October 25, 2015, 10:49:32 PM
No Yenko, I had good laugh at that BBLU interpretation, since I would think you could see the holes for the heater hoses for a big block right below if it were, but...... "its still no Yenko"
I wonder if that can be seen on my firewall....
So a question for you guys that located it, are you guys going to go over it in crayon when restored?
Post by: abiddle on October 26, 2015, 01:12:08 AM
I would grease pencil again prior to paint.
Post by: NoYenko on October 26, 2015, 06:42:25 AM
William, bright blue does make more sense. Even though it's almost totally covered by the AC box and not visible I tried to reproduce it with a grease pencil.
It's interesting that the build number was marked on the firewall after painting as it was totally visible with the air box removed. George
Post by: Mike S on October 26, 2015, 07:53:55 AM
 That has to be one of the most "natural" looking factory restorations I have seen of a firewall, George.
Post by: ZLP955 on October 26, 2015, 07:59:25 AM
Agree with Mike, that looks very well done George. Interesting to note the right hand stroke of the 'U' passes through the A/C harness firewall piercing, so presumably the 'BBLU' was written before the hole was made?
Post by: Mark on October 26, 2015, 10:13:44 AM
The build number was most likely Chevrolets build number, Fisher would have no need to put the build number on the body since the cowl tag was already there, and all kinds of paperwork was hainging off the body, and the body was more or less locked into their scheduled build order once it started down their line.  GM needed to make sure that drivetrain and front end components for job 348 got put on the 348 body tub.  Although unless you have evidence of the number being under the A/C evaporator, it was probably out on the tulip panel, as that area never got covered until the front end sheetmetal got added.  The number in its current location would be hidden as soon as the evaporator went on, which for all i know happened right before the front ened sheetmetal drop.
Post by: BULLITT65 on October 26, 2015, 12:09:35 PM
Looks good George, I like the way it resembles what it looked like originally.
Post by: NoYenko on October 26, 2015, 07:37:51 PM
I learned a lot of tips from everyone here on what to look for on disassembly, that's a lot of the enjoyment in this hobby for me.
Thanks for the nice comments guys. It may have been written on the saddle bags also but I didn't see it there. I tried to put it back the way I found it even though nobody would ever see it again. Found original picture. George
Post by: Mark on October 26, 2015, 09:43:24 PM
Generally if its on top of the firewall blackout its Chevrolets markings, below the blackout its Fishers and obviously it belongs right where you have it..
Post by: Steve Shauger on October 27, 2015, 05:28:33 AM
Quote from: NoYenko on October 25, 2015, 08:33:54 AM
BBLU=BRIGHT BLUE/ Lemans Blue
Post by: rich69rs on October 30, 2015, 12:02:18 AM
Only firewall marking found on my Norwood '69RS back in 2004 was what looks like a "2" that was not visible until the LH fender was removed.  Have never found an explanation, but it was clearly there.
Richard
Post by: firstgenaddict on January 28, 2016, 12:07:49 AM
I have only seen color indications over the top of the first black and on the car before paint.
(https://lh3.googleusercontent.com/NgbhguUpLoVP806FT69ISK7Z0geX91RenA6W0qab0eqp7abJ-PhGGxNV1fV-LgDU3rpybTcrfQjvQn6f3KPhSLyOAunZ-6sAj_h-yfDQZx87hTCzQgKT9Q09Vx17L28X3EjY07ojYvvD8KvjbBd8gnkk-VDR3thJ_lauN1d1oRff_ksd4f-fZmgYxhE6NqDZQzZNZnAqawk9izB0hnKFY9K-z2Fq4kH0lj9mFNlkMhAkFG-E2hha4BepUz3vnzF6SRYMptTa1ltxXWTqIQwDaEkc2EutGXhGn7dtHZvJIblmyFTAIcdI8j6_FKn64_o7YcGchpfxNNX9HZPB4aCaO_FKpKFRZ9nxR1YDrULOySbPOHUxsJ7btsn0SFH898bsURoYTQ8t0LmNkqbwT-0z-Ay2_dOYGAqH2B0j_UW8vaY-Vvq7nCS9bCu4T5pu4cM6j8pskpMWSGz_h_M9z8j3Iot159BFbn-vE84i_7K2OsaihU6ejaXzFXr0PYScA7GhSbT3foM21SIA7dMWxpfCEkAKSFcUfa56wdaFC7J2ZIGIiQq0hEHIcV_iIEYvEp06naT0=w1187-h890-no)
LA Car... unrestored   since LA was multiline I have found they use codes instead of descriptions of colors...  71 here in yellow grease pencil
(https://lh3.googleusercontent.com/S4xu3Ka88GyPzvDIFO720iCtp-F2DXrWu6PXf7xRQQ2Wr3U2Lc1OZRIs5hKDOCqqjAsWABQvz_-W7nguyJ27DudElqfNO2jYClTQPVCklRO8w2AyD0v_6FitbtOMbfva1jFyqSm4HrOePaFSL7z-19d5EKR0SVN38DyXpktKy9GBttcPRLF22aqMZ1jxCCbfjbRM-H-XEIwMw3e8BviJe2maSQo5oF9ltlEN1_taOYVfYmQxT0CDV-gdffdiJXCQ1SoTKr81R_-SdnL-oJBq_NUi4XXCpHAYvyx-mlqZNL0-6FzxUhFDBDlaizmJAQpbJsZ7xrWD9elmHgCAhnRjlOb16M8-50TejtZ3hkIx4WnePEifXL0Gk6bBAfrTYmeG_r00LbnAMfbso_OZIgMjYOSSvc_RVeursHmld4dSmfY_R1GLwn_JfyiydKiwGzw9aqz-34oVPNylXXiYrZxucaHOmHiS-CMeLa7PsN3PwmKKFUvi8BS3C4JHpZh2TIuJ8_oj7dI-8glSXuUdKQseS_rV1fcQS9h1wr0sumzRSmaqnHs7utmnWyXIwmmdbysSly8I=w904-h678-no)
(https://lh3.googleusercontent.com/NY92x0AnA3QrQ6z4MyWR7M-cvF63gp04KgA6-M_jeNodZM4I3BtpEoxF6WdqctrCFRXs8KJKmTLuA89BBP9jukWrwkq01bmvnG0sYesMW3xmLk1bZX6af3Yj5jtG_jZ5D5UvnCFJJWZ8D_lTnI7kUgiYswYQpYD4yimh5bvJm0L8tYs5OwHNKYJw8xP7G3OwtGRqWYX4K1bKzXMgGulyoP7ERUc7zzUf5VOixqH3yQtmn0SYdi_0rjcOWj1OwxgYOPKfhuBlTJ4L5I-9RO1nSUjaKI7LBZd1Hblo83lSxBWCEJ-iY8Uq14cHyyc0BlYaxxxpIiOo528pP1cq3abhmAEAjYOrzb2S8iNK78tjwV5waVr1HLJMde0NDnwm8kxz-0CARcCp8PsBL7YG99Py9oyIHSnG_HOzQgsJwRG33pJ-p0jq008-p6drPNCF48lfAwRObMk5RajUtBkFbtFo8P9EFAlISPVwJltpvfchoVq024cUBBKhMBdnKofSH7sRxMRxWz48K0THr0dtEJBcm3V_JV3IBzm26UeAoXqBginzeaVB5XUHm5FD5FmDwIZvymAQ=w904-h692-no)
(https://lh3.googleusercontent.com/iXbILvHTEIilmyroaBdrdInRSunKrFBr3xSyF4zSqznp4wkqzpZ9LgfNBT6lIsSLCVXiVwrGw39s2sOeknxXD2aRBadEqG1tQl2RpmWQFwT5-a43gcTKQQ8iK73R6NJtuZKp8GlzjQHA12lvjWXVJ4FwYUKk8_Z0YbSvFyHzm3MzDma4Tsh4UuCSR_g1X7lEvrYEDOJKsoMQRdsNKsS9smYBaNr4eUfHiqv_bnpmC0N6FkTlOVPR7bVb3EnJ5MU_1qkFC73RgMoXmSUfiRDP_6P14XkXLei_kSMYjKWt4Kb0-2FXWtJDO0mho4BswkU3rsmdS2vGU0V-iPpMX7lKrPNplXe6t9gME8YPV-YmkmYElzkCySguF7zNfVE2CBg--X3gTem0paTUHA6qSIMK7yaObd8ao7PYIFkk8h1FFgFRIWEysH1j8_kX1YZBr_h-afvuu8Rj4iV96CRSC_vrwE44tFRZcWwPbkzuILTU3pQyNU3iMqeiGJB10RXoX1v_8UBZDptJuhI3gF07NJnRJQmO5uhOQCYGLqs61RIT9RbO_HTrNpS4PNsKOrVarp_-V2FL=w904-h678-no)
(https://lh3.googleusercontent.com/Fy0yzObtluvziqjwtxpxAMzjQ_AXXgvLv-ak3r5Gr9HBZB4dk3Syvl3fc2rj2MzASl4kQWNK1vGszP6Jr_4ld0jZ_1pemhyYGW_kVzM1OH0lj6BnpLPRDhJG5mQ9J4AWkoLF5bXWt_zlxdKbWIGZnIc-6wU870TEHE0R-XZiD_cYGe64jqAT6CLG2Hm6d6DyZkrZ7_O7q5p2FogjHhbSxEG82xfEpI4k5KTtpLfD9cPLn_kfUB6iBFAjcBZ8zbwx5fQNdGoiqW9mDPW7IB-IcUq6XM42v1YiG3PUQx6g1uc-nkHEfIyeWGCMxnfnwb6q-WF-RT3tXTkKyKtLzXW94HEbfXmsQdvrdApqvIIHpM_kW7anZwR6Zr0Zvl_vAvwnQ0mmG2g-KrmKwHGnMwp7vXEYuqpk53ldMnEiZn0Gj3yMgzd7MlMFT69fCHmBEsFl5qX2gybi7l-rxQ1CeS2l1XJwBsQF8y7tHjllmDoKwWid9zzUhUQSjvGvIcJi20iFVK-FRnnJdTEquvhTwfFWlwE5uH6wnEZWb-qW9afu7SOr6FJoHEu5CqrZRAtUKH6GuyRG=w904-h678-no)
Post by: dalealan on July 18, 2016, 12:06:55 PM
Here are the marks that were under the A/C box onmy 68RS. There were also chalk marks on the inside of  the lower valance panel.
Post by: firstgenaddict on July 20, 2016, 12:27:00 PM
Dave Beem's survivor No stripe Silver 69 RS/Z with - -  has 69 on the firewall.
So obviously the color is Cortez and the - - was for NO STRIPE.
Post by: KurtS on July 20, 2016, 11:05:42 PM
I don't think it's that obvious. ;)
-- meant see instructions. Could be a different color stripe, no stripe, etc.
Post by: firstgenaddict on July 21, 2016, 02:02:07 AM
Kurt,
Sorry I was not clear...
I meant on that particular car... since there is a 69 on the firewall and the car has original paint sans stripes.
Post by: KurtS on July 21, 2016, 11:38:57 AM
Got it. I read it a different way.
Post by: Oaklyss on August 05, 2016, 02:31:25 PM
I have yet to see anyone able to copy the style of writing on the firewall in the same smooth way the assembly line workers did. And yes, its under the black out not on top.
(http://i145.photobucket.com/albums/r206/OAKLYSS/69%20SS%20detail%20shots/passfirewall.jpg) (http://s145.photobucket.com/user/OAKLYSS/media/69%20SS%20detail%20shots/passfirewall.jpg.html)
Post by: firstgenaddict on August 06, 2016, 10:11:40 AM
you have to spend time trying to replicate arm motion in order to get them to look "more" correct... think about the limited amount of time they had to make the markings...
This is an engine compartment done which has partial original paint (inner fenders brackets etc) and the firewall was redone to match the patina of the other unrestored parts. All of the phosphate and bright zinc were original.
(https://lh3.googleusercontent.com/frF-Wutwl9FMhrqg42T5e2pCeXViSsG328ZPwWysgUFvb0RvpuHDDFythnfhq9u6Swc--v0K9pD0HvTB_pvZSapugQ59Yka-Nlo6rkbg1fDlMIgNZGPNQMZRZBPsIHEpGoyp0eXuEHklDKa6Xq3hygG0msMrG5wzimJ9rOB0ZGu7NjSMoFNtu3_PQE_WHtsecMYAW85HpNRKqBA_PiZFvV_3kO5xIP3Qfa4I9BZUsUe_woIxPIUMPfmpQjJP8OUFHo6LIuHlvGtw97hU1zvQ8sQNkMTeiK6hVVdumVtPiSVVevDt2VyOAObaHS_l0UjCCEndvLk1_biNfaThIqB86AphbU-BT2EdmYN4YwSvQigQAgInQQ2CHegQ5DvFMrUoKc5jI7G10OBRb0Tm5M1lWSZWW1Jv3O1ycFg63mUZv3qy_svLqIktbe3dhAyJm7BgKzP2xiArAXMZNHRNgAIOXMQ6Nx5juJ0X-kqIpiUiI7OL4eINITx0eLCsDC0oUyFILuQchRcqKoiXok5Vj4z5fCLCr9Sr-g29Bc0ScYKAo85AmNbtXKEKLLX673dLsVgRTqGxtOLJYlwozWHWrj0CGKAvtSt9H9x1=w1920-h1280-no)
(https://lh3.googleusercontent.com/7_rlA0iB--KTMYvHXkfnSl7LBEVPkGm9Rr1FaE67X0BPnDJrKrUIJCS1PWZm0OpGt0QejHkZGxfPKFRFfzxgxSe5yPrSWcNl_S1zIXQcygatzvH1jpSXbj9KmxOBV-5_hwZH0uHrH4sXsivwsw9s8fmfwgY7tSJ0J-Allc1eVwN6Y5HtwjyVnUrC3RinnVZE0WP6yWhesbrYvhvdND_66qRjcX4ipOa7FKv16QHrh9TAGV9c_or4w9aB4R638OmdlfId3CvFPTM5T_zM2EVUAkS6LgFdbbkg2Vr0qKgHqIkCXTK0SICnh88Z5yx1j_Y6-upCVGDXpQ_5t0mx1cjP0TAZ4cfbVWX67hd2W89JecyHh15A9AzZK41c7g9Ay6yJkNNF6GvzuiwXEyQTkOApUf0DnetkLD0ePQ5_NbRoDmFBOVlrgpBm_IGU0zyoNUloDwIR8AuBZUiy6iqvYbG-lxSoxUnxkwQoSldZroWRykmjxVr7gUEmLGLXoZzMNyujGFkwW5nygx10-J1GI1ba4FqN7LFMYIWaMHCSd6XyalxB7L0MfbUTrlNMHjJbnAYdyHZIKlPC9MBAVF_3c5E9Tp5jLzqOwi6e=w985-h664-no)
(https://lh3.googleusercontent.com/u0phaxcOZOHEoqM6n-QHLh1FdEAAVHENJNpSluQVm35XNZTeyRdNLJuAWcJR69pTm_ZWEhRONnzmoHRa0YcF3kkYCtUYL7dYLuQ_mubr5RoFnIsYAocz8VhIpqmPEu2uUlwuQA9XrQvENism8bpFLr8I0nOpU6kd-NqyIHYLzkeTdwn6QgwfX1Pl1DFEqz_mIkLviM67JnCFY41-0FdbWRUGLU2lt5tLqPyRL1MK9IqzA9d2T30BZOAeJ9yHYG9Ic9wKGaY6rFZWFNVon-AE6_o0sQGPxhHcUF_Rc0PULvNFwebLeWeTPp5xwObWQTu3yH_nZ9xEktHG-eRDByY3aMQQIwlq1COKftajZo-Cq07MwS7R_5d07bshmuyUPt7rhkbw2AL9174L-nQtNzH6P7su27r0pNjMPZOfTaMOGsYVkPMg39ZSkqjeJSvF_0HNYnH4-6W9DruzC_eecgqzNGM9iH78VuAi0BwCcgeU1SNs-NPwjHlR5Z9bkJfhHYGvQa4zPNFDsi5sPUug6F_uP0bOZiQsqQoI3iiPIDlPaGEPh4nNdompikNyLuCmK3H8SNZ-2R4yg2nzEAhpqNYvX11XSMs7ghgj=w1003-h671-no)
Post by: cook_dw on August 06, 2016, 11:15:53 AM
James where did you get the rad hoses for that cortez vert??
Post by: firstgenaddict on January 12, 2019, 09:13:44 PM
Lawrence got the hoses from Pace Car Jeff.
http://www.hendrickperformance.com/detail-1969-chevrolet-camaro_ss-used-15619172.html
FWIW the car is for sale at Rick Hendricks. and has since been certified by Jerry.
In his report Jerry unknowingly paid me one of the biggest compliments I think I have ever received...
Engine Bay - very good, minor replacement components, engine bay is very original.
I completely restored the engine bay - There is not one surface which was not touched...
ALSO In addition to cutting the overlap off and butt welding the upper seam of the overlapped bondo'd in Quarter panels, I sectioned in part of the rusted dash at the windshield base, sectioned in both rear wheel houses, and a sectioned in a drivers rear 1/4 panel trunk drop.
(https://lh3.googleusercontent.com/q83mQDYmwtYSINkcZgtoFfrQp75ncykHctxEEEMQoWZwhKfkSJo3inw6svvbRMeLARSHc3Hl88re6mAFrr2TIs1LQia2GlibkPQEkj0Kkan5MGLmvsRwBBl8Ss_sEA43cwYQxM0ujok9fkTFYx2fzTyB4dlr8A4w1hjlhuF3QIT8o6VpfZ3eWJX3lciVMLzi6eKZpjgp3PrkV3ACvtfEX8Ccr7xbqntGCUL3dXdyG0bGpwTaa5ILnjNm1qJI2hOvto6cd_8BeRvLUEZGyw4ehHPbq2tYaQjZr9KOMPKfPHxYQz3HHJtfQhoIkVgZGmoF5s-qh1gXW_PV5wSiIFl4boBqGmWzBL448L94GgYLrScxER_fwnU4PyRai_2IlcsvoAe_lAOL5Rwhk5NHkKbTAZksYKAfrhzP3uiVPUFelPSqpq6vM93-khCRClo_EvfLQWVTN6nlOe-6Ywd5SS7NEQPh-_1On4iAqkPbGoIEVRzLENL3R-gxWcyX33NmDV_-oYw_WRgmV7WA0aNmmlpnCmHIfreUjkH9eCFvofRQILojkCv6BdtXSwdd_v0UB_ovluok-xA0Z3L177DRKNkdlB9KQ830Z6G25nIWc6Sr_af4K4vYBtRLK_mi1pE29H5v9dnniQf2SEbcI4NuDCpIF8gmiCHqXvHY_TvduNDcTucBmrGI8r-v-XeQZN1VnYotQQns3QiXGJgeOrIGBFw=w1601-h1067-no)
(https://lh3.googleusercontent.com/LyR8JGxWui-rXUayA2NH5PipShcudmrDp0XLdNvT3UX245XCHvI0laa5E6MK9lU2KsYW3PwxDxin-a6o00WFMAyFCmMb_61PvkeFJYGcp7xyr0TR-7lKxH4tGbRMYBBU4z4tZT-zJaZp_DUmFsy24_seSnu4peG9mcROO7T-oRZWtuH8OVaB6ErqvqLcmhxw22rmBZVtS8Mckze3gLebFlQC7qiAIJSQr2ta7uX_e0J-FWa4hBuWpUbXBNcuECwrUPN3sCcXBRGlxQN7Eev3fxisgH8hbmo6WJQwPrSd0GVD8J3btHDOwkdtgEaOcf-Q8s3_XNtjVGVi6Uvh9hMlz0n0Nt7auVvPFVv_Yp8DLTKMhdmfFJicazYOeO6fPAdGiMUduwnTB47-puYp8SY2oMB8c9YD299N1cCeFgkGULdn2mQBnWwUEOOoLTxrpiMumP31lf0O35weCEThjSAIC8UdoG0hVM2zBH8TeWIhIMjctk0ofpxhNvtVKlcV8bvz0BXQtfQeuZjrLb-zyxQo-hA_ks2oo3UFnClfr0JQHEUjH1iwbZHfJN3T-zDKLAr1pZLp4kcCEOw0Szxw8rZu9BI4tSGgYQMj1niYna5OGbufvILSYotwu83Ysiy9yeAxL5GSvHizhoj7ncrduIpZ4Nv1txMAdKSoXPKEq_2OOGIeDNGyRtGBpdqgWc8tws_um71Ci9QnN2u0hM20kNk=w1601-h1067-no)
(https://lh3.googleusercontent.com/Hhvm0eFB6cgKBzyKUfbHXieNiO0NDVAyXtDj7mke3BJ-C-1jKq2xldXp-HceMGEiWaaHeNW1Pzi5dRrnPZOnu7qp2quwxytFQMoNm3Uzy5gWcBG_8oBQO_6uBd6TZc1wUa8XE8Tp6v9c_xnDTYPtkg9wbv1Q7H0tQPEvTATQF0YkW02_Zmn9eNB90dWObOI_6_250LTY_aq1YRvlmkbHBMF8SRI_Wj8wMim03C_jRb-XR7rjcp00A72Bd1E5Hm1KHSzC_PDIy8VajhLjCsFLItJYIJ4ZRnfEyr8fhzTsgH_XAeEX8JZ2BqthD_apddNzTveQC1frTAkAhgCH477k_wzeAp_HuE4tuS3r7EDH40K7VmuYHDvKyZ9gBOp43ahjrqE5mDQ06vzcfDwtHjc8bvKHHN1Xz0NpiV9sns-lRPwTaJVcch3yWQPGKj5-3bVHtWqJUATrO05HT173SYXiwGf65IRve6YfG8aQYnx-P6vwSI8Hb9gXKNe30lMZzoiwWJyjD-Imxhy5mrh4Y7BdVci9vqovU5Yj3PlggvxVcsSce7ZdQibQ3YdtQ0snspqnmxIsqCwJKqITYwCl7Ig-3XyTroC1xhCNTO_wSCmqzq4wPV7X8S7FpBF2GBQsQR3CW0YyJL87lWnu3ceRPhVv7lI48wPCKX7afNluLaekbOXK-y93KcIKR4aWCTzVtvG2-Tkp85bd2-Ns3ePDCtU=w1601-h1067-no)
(https://photos.google.com/share/AF1QipNAFJTcg1AKyr11B-bogbF7WGI7253c5dH_TYGFYUKmzDxC-DztZ7qJwP_jYfjLPg/photo/AF1QipOh4maKhipJIVhjDGGQ8yq0Grnn0Orf8tHNRROK?key=WDRBR0hUbldQWHhxRGxMSkVPSEMtZ0JtcERkcWFR)
(https://lh3.googleusercontent.com/iWltPoQnqhvfs5mi4Q0U9bLEOxUI_oV0tQhB88CI2e-jC983ZGPICr3eQuBC6ugl-ZCL1wfYGYMdlH2fjmSNtTaEHxpGgYHXYHhhFla2l2RWaaUcmd8wTu6lJjxQ9WtxiPdIF0hUrRNpX5p4k-i4pJenL504qzo8rBcaxE7KWS6r6MQWB4z63Eu8vibLzToPqf7UofuBt0aJkYbImFJVKoxMtUFwN7LLeqc9wkr6Tx9D82jmoIS8nrWCtKtPvNYTiXS5OwrzyjLLqHm6CuTQoBlI1m-2gBmvl_BlcvTUcIduJy5AwpqBpi7yarxX0ttncGLrgtkkOF6unmKWfat_vNpH2Dnf4hQa6XFxWnamAWtEUTOPx6HDeqkA-djJG2DOmYLkQOdxyBxLFg5WpNTIekWdqIfUeHtvA3gBSgq_YBrcJygtaQE40C3QEiUVXtS1_acgXFPK9XCx-L32agItkdUm8UHsMEdhuf1_5P0STn6nAvKmVcIrVNrNnUk36P8AM9JfM9uvMv4DSjhrSK4kbCnxvTV5laVQw3xbFg1vtR_2Lo6kcjfgb7zC_qmIfMthQj8NK17FV5MEwvVs4Gc5h_-Kql_6oyWAon_vlm-MttmTS5rLCUyac7eosbvSECwk-H_-DsjluRE0nxyyQXJt38GjkXauCybiGr-0y6Im0XADiAgN5GxVXCSSHv4AK5zdEjvovarD5NfhpWuxSVw=w1601-h1067-no)
(https://lh3.googleusercontent.com/7jY7OEJFePegQBX8cXRwk0Vq2KfpP3NexoT0TkG34DTSTquaMPdUu_leJTq0whS5lLoNWPTgDcLBG3H0B0O3shxJdrYDL4TRzQlWnycHCt04DltKgGe5oAEuIOrYZ2AMiIBKL2i0hIuGFuEmbQmHwUeLwjYrsAMzX3oNkDtjbxu_ujpVHXCs7lJ4bILltXpzyoOOR4YGa5Ebv3fYfIRht1kSAfDIPin-EOO8F_Z-1s_jdPh4i7eQkWC-BmBAXgqMWHrcXjG7iwSHRzu2_OD9qh6y8VLMzp2Asq5u1bVbzuzBEC6Ox6ptVy0uSZwLDDZCGl1XkdmhVHE8dshgq4i8ynZuosYVq3_pEplBPSJ0eaHhZLqpeMqLljxbNPZN21h_dMR26oSVQURywpVgUMmpeaaNCW7Hu0EoZm-sAAOI_EJsrTeTTOa9s5BWE8yZjoaxNxrnblC7mqByShUttAx1wgy1WNdtPAoeZt4JAuxx_fqaiG4VjQECxsyb0idWaE7Bafl_3PVzzEBPDgKvmgRnFIutvCbQiA_b8Bw3iVxKi4pfVNyVQQNF1dsFBMEjwua5Frin1hkiwBRF0QETaFIKV_KK8jkvGflBAyqNjfgqfnD1tqIs5c5jB7xM2a2LaOzLNkOZktOM77Ci1vx3cPkTnx5U0tzmXszreI1_wxizKEPQCl-_0diL0T_uDc7vBnGeZN2XERtwmylAFg7ZPXg=w1539-h1154-no)
(https://lh3.googleusercontent.com/XEUUcjjsk_wXOXnN1NuZUUW3XnYXeFAYN-bbwUuGBhkikbtKhogWN_51EK-4HedQ6pgy6_TdjMzzWE3oYgEwK7O1R6cu9Bvx9YmRCIAE4bdNMvCtCO671PaxWycTT4EqUglA0k1rXY00QN09pl_bzBHFjrAzI0svEkdjMDEHgGjK-Lt2oGg4kFn1Ysgp7NSe1RrrdRdQRzNiIdRoym1qo95iBDPEI0W8L_Nh0KYUmO8Odu3fAXKl2D42wb6WNcjfWMpRhA5HXsO1gCWwsTYzHij1uUV0_jy3hriJtPzLzS0qG58hA5cdZ505giff0nHehOcSaU-luMplJIRfdoFz-w18Um-Lmqk5NcKucjx2W2fMLMq3hpw1QXfq_gge74PZbKWYfImm6g4RfuwbwyX3u3jlttYUIUzfAXNyPxj4OBC2BECq73-6SzUnA1rxdzVOyjqwz6LnBzx9Au2U6BzYaArzQwx4yx1lglhQ53zsCX8o4_hlHmzQnanOAuBNnWICcM9FoPTbYFFqaLw-4V6YB1Zy0LnqtNzZTFSU_jriCsbcVmMLJu3ups8PszMfUxShJ284vP_d9tO3pLBVAz7YOF0DKGrwZeR6wyaST1mZZTGQg1EXGD1-eJ_wyjGkA_i5mx3R7mZyFUJ4TESqqgUNpZz3f6LPgrgZYehcK8j6TMJJ1OCUJR4SYRt2YwHfHyvTqkJWmflFo2VdoalrVOs=w1601-h1067-no)
(https://lh3.googleusercontent.com/r-bNzLAdhMg_QGWLh9fGhYf20dlLMqXcl8cVGmvaUL6PD8q_IyUH6ZTXlwWA9aRvTV6s7F3jX3C0cM8f_CdlYnPzWd-wAOkEwM9wTeQUG3WKeSMItUpLUszSWBau26qWFzH6i-CgDO04LlYMohL30cgReEkwXdhQMRgU2VdeNhUwV6apmuWZ-Kzud-akvWPCqcEJS4i4PaNPV4y8XgsG5OXjj59fW6RRyEHT_Vs8clTH64H21TBY0GIYXV8b0BvC4v3Vmcg36hgxXr2OpHxN9c4cTxY-5iRFGfB7qE4QaNBJTfpb9qLkBZvXrnCuS5Ebt2XvSGTbJMSGzfp9r9k9gl7gdLtoQTagQz_J0VADcalU0gXcBf8AANhhmS4GXooOz36Mbqf4NxBzXZGSwHmdCLYmetjyKaT0SrSMLCYR54dlpmX3wIHVz87m8niT4lo7Y2Es2m29mgH6PfZgp3RoHFePGu36y1hHx7MTPE4fccQNkDMGawnhnUclDqS8VaorhVg8k5CqfRrS-YS0J3lMpWvQfM2tQ7qvgp0wge7-a1O5KPm8MSCATfxuIvsQxPxLYgMS5oFf-Fg041xGy4z3v32Dbg06hEnrWlrInZvIYhZJTYx3XHrOGIwZccVvy5aKGf5gTXYtC17pL1cWGdMXOVCCDOUlxJhvrehR4SaU0cZ0QTuKrJLIeuGxU55Aj2aKGf6qJHwdz5lW3SFhST4=w1601-h1067-no)
(https://lh3.googleusercontent.com/IUqXQGyzcu1ZXwE8HHNISC_5qKpkamqFzgYRqPky2TeKV7Lpoxd1MTOiivziSy4M66c8rHUXV2S0Ntp6ra5zIz1T8kw5ygCv3OrdA3pqLjjLl0qtgQhHJndMOMCpfFreN0ZembN5_m0XuPMyhSPPT_HWK04hQHem5MZ85a1vgcuLzFQ57uKHuNpSVYXf1HiKn2aXQYfSABKkavR0lM0FFyulGH2xGi3Bqg5QW0ZwmlHIeQVJg7Izid-7PVo2FbLAisz_xVNTZ09QSH6PLnFZcBOTS2MdkTl9d1qNwQVl3Nm1nc1SroaKvvewgiZswbmP7gQVwvRloJw81Z9q-EZUqq3QepeEStppz7bXu_1W_W892T99x49-naGAi-eBlKneI1auobxVFK3LXxBTKzPFaRpzvGruMXYTvMUTWH4Kd2Cnt05GYeW4MVX1HQICfl5cQwv0MBbfbAAJVmBnkho1ygDs0UBO8zLirzUTF9pJJpssP0yqhxhpzWa5kglejzpWLOWGtApTATUKdtbuXXeh22fX45_ojo2pyxY4YqFgtlqcpeLv5nE03knf5DN-woFCRgqCzu3A6o0i84dbZur2A21kyqlkP9cxVju5zbizinXwlu1dQlWeFDbc0mhIqvujCRB-oWzhwrU4qsKmh7MM8ChMiity9QnoJaN_gM0KVVb35zQ16K7pd40dLSEtUHiql06Ohi4wX-ORu04cXlg=w1024-h768-no)
Post by: 69Z28-RS on January 13, 2019, 12:07:48 AM
Congrats James!  :)
that sames a lot more for your 'restoration/preservation' efforts than it does for JM's 'assessment'...  :)
Post by: BULLITT65 on January 13, 2019, 12:40:17 PM
Very nice work James. I also thought it was interesting that the LA car did not have an emissions sticker, since California was probably one of the few states where you had to keep the smog pump on, and enforced the smog rules for years.( unless you knew a guy that could get you an illegal smog...😏)
