I just did some work under the hood and when I hooked everything back up I had no power to the Horn, Fuel Gauge and the Acc that I use for my after market radio. The first thing I checked was the fuse. When I found there is no power to the fuse marked "Gauges". I tried to track it down with no luck. Can anybody give me any suggestions on where under the hood I should be looking. Let me make note that the original charging system had been converted to a single wire system a long time ago, and there is an HEI ignition. There was never any issues in the past. I am afraid that I may have messed with a wire unintentionally.
Mike I posted a reply over at TC to look at.
Thank you!
no problem, and I posted this morning a few wiring diagrams to help you troubleshoot your issue.
Excellent! :D
