Camaro Research Group Discussion => Mild Modifications => Topic started by: jdv69z on November 15, 2005, 12:22:44 PM
Title: 69 Z/28 Front disc brake upgrade
Post by: jdv69z on November 15, 2005, 12:22:44 PM
I am in need of front bake work on my 69 Z; my calipers are frozen; anybody done as conversion to higher performance set up such as offered by Wilwood or? I like it to be bolt on conversion. I also like to use silicone brake fluid; This is not recommended by Wilwood; Anybody know why?
Jim Voss
Title: Re: 69 Z/28 Front disc brake upgrade
Post by: JohnZ on November 16, 2005, 12:09:09 PM
You'd have to ask Wilwood why they don't recommend DOT5 silicone fluid, but I suspect it's because they assume their brakes are going to be used for racing applications, and silicone fluid is the last thing you want in a race car brake system.
Post by: tom on November 16, 2005, 07:45:32 PM
Dave Pozzi (old forum) had a whole web page of info re brake swaps with other GM brake systems of the same era. Not the brand new high tech stuff, but still a whole lot better than drums. Not sure its still there, but its worth a google.
Good luck
Tom A
Post by: bertfam on November 16, 2005, 07:49:55 PM
Here's David's link... (http://www.pozziracing.com/)
Post by: KurtS on November 26, 2005, 08:16:00 PM
Just swap in new calipers and put in some good pads and you'll be set.
Unless you change the swept surface significantly, an aftermarket setup will just cost $$ and not brake any better than the factory setup.
Post by: Ghostbuster on January 03, 2006, 06:19:55 PM
I replaced all 4 drums on my '68 Convertible with SSBC hevy duty conversion kits. Front and rear cost about $2000.00, and the kit made it very easy to install both in on a Saturday afternoon. After doing this I found a website that recommended junkyard calipers or even factory replacement calipers up to 1982 that will bolt-on..
Disk Brakes make a great improvement over drum brakes, but next time I'll try Checker or Autozone for factory replacements 1st..
Post by: JKZ27 on January 05, 2006, 10:28:37 PM
Remanufactured calipers (single piston) should be cheap and available at a local parts store, with or without pads.
good luck.
John
