Hello everyone- my driverside power window regulator finally gave out. Does anyone rebuilt window regulators? They seem to be hard to find. If no one does, can you recommend a regulator that will bolt up in the factory power window holes?
Jerry
What broke?...Joe
Three of the teeth wore out and when rolling it to the top, it makes a lot of noise and bounces a bit. I thought of welding it but the piece is harden steel. I don't think it will hold
So just the gear teeth? You should be able to find replacements somewhere. Wonder if Caddie's used the same style....
Pontiac?
