Camaro Research Group Discussion => General Discussion => Topic started by: BSMIT59 on May 25, 2015, 07:21:38 AM
Title: White trim tag
Post by: BSMIT59 on May 25, 2015, 07:21:38 AM
What is the significance of a white trim tag? I've seen this mentioned a couple of times but no real info as to what it means. I have a 67 SS 350 4P car 04 Dec build from Norwood that I'm tracking info on. :-\
Title: Re: White trim tag
Post by: My68SS on May 25, 2015, 09:05:51 AM
I guess you mean white paint on the tag? as per this thread
http://www.camaros.org/forum/index.php?topic=4727
Post by: BSMIT59 on May 25, 2015, 09:48:00 AM
Thanks!  Just storing data in my little pea-brain
Post by: My68SS on May 25, 2015, 10:09:27 AM
Quote from: BSMIT59 on May 25, 2015, 09:48:00 AM
:D, my pea is issuing 'stack overflow' a lot these days.  :P
Post by: 68 Ragtop on May 25, 2015, 10:36:05 AM
Quote from: BSMIT59 on May 25, 2015, 07:21:38 AMI have a 67 SS 350 4P car 04 Dec build from Norwood that I'm tracking info on. :-\
BTW, 04 D means 4th week of April build. Not December 4th.
Post by: bcmiller on May 25, 2015, 10:48:52 AM
Yep, there were some that were painted white in 67. The tag on my early 68 also seems to have had some white paint on it originally (09C car).
Post by: BSMIT59 on May 25, 2015, 02:09:56 PM
I'm sorry, the tag actually is stamped 12D which I ASSUMED was 12th month 4th week
Post by: bcmiller on May 25, 2015, 02:18:00 PM
12D is December, 4th week, so you were correct.
Post by: 68camaroz28 on May 25, 2015, 04:32:12 PM
Quote from: bcmiller on May 25, 2015, 10:48:52 AM
And other years had it as well so it must have been some type of common practice.
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/Trim%20tags%20and%20stampings/100_8375_zpsdibwo9nb.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/Trim%20tags%20and%20stampings/100_8375_zpsdibwo9nb.jpg.html)
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/Trim%20tags%20and%20stampings/100_8372_zps6tlfsxo9.jpg) (http://s192.photobucket.com/user/1-2-b-67L89/media/Trim%20tags%20and%20stampings/100_8372_zps6tlfsxo9.jpg.html)
Post by: KurtS on May 25, 2015, 11:03:16 PM
It's been said it was done to highlight the data. But why did it go away in 68??
Post by: 68camaroz28 on May 26, 2015, 06:44:55 AM
I just always assumed Kurt it phased out since (using the 68 Camaro for example) there really was little information on the trim tag to begin with and JohnZ has mentioned how the plants were pushing employees to utilize the build sheets. But agree it would be interesting to know what happened. Maybe an employee put in the suggestion box to eliminate and the money saved in both time and spray bombs. :)  Talking to one of the retired line workers at MCACN last November he told me he made a lot of money with the suggestion box!
Post by: KurtS on May 26, 2015, 12:04:23 PM
Build sheets were for the Chevy side. The trim tag was for Fisher.
Suggestion system were always suspect. There was a guy that got a max award for changing the keys to aluminum. That was a problem so he got another for changing them back!
Post by: Mike S on May 26, 2015, 01:47:36 PM
Quote from: 68camaroz28 on May 26, 2015, 06:44:55 AM
I just always assumed Kurt it phased out since (using the 68 Camaro for example) there really was little information on the trim tag to begin with ..........snip!
To me, that is the most likely logical explanation for being phased out. I can see its use (white paint) as a visual aid for a fast moving manufacturing line. Maybe it was used more as an aid for the PBT inspectors for verifying correctness with body preparation options being it was painted after the firewall blackout.  It's all speculation now.
Post by: RUNUTZ on May 26, 2015, 02:03:40 PM
Why don't you ask the Norwood guru?
Post by: My68SS on May 26, 2015, 02:31:04 PM
Quote from: KurtS on May 26, 2015, 12:04:23 PM
I'm still wiping the tears away!  ;D
Post by: BSMIT59 on May 26, 2015, 06:15:27 PM
I'm gonna throw a little more fuel on this fire. I also have an original 06E build from Norwood with the white paint also.
Post by: bcmiller on May 26, 2015, 06:40:44 PM
Quote from: BSMIT59 on May 26, 2015, 06:15:27 PM
What year?
Post by: BSMIT59 on May 26, 2015, 07:02:16 PM
I'm sorry Bryon, I thought everyone knew that "Original"only pertained to 67's. Everything after that is a copy!!   Lol. Just kidding, don't want to offend anyone(even though it's true)
Post by: KurtS on May 26, 2015, 07:35:56 PM
Well the UOIT tag was on every 67 vehicle and was larger and showed the options much clearer than any trim tag.
Post by: bcmiller on May 26, 2015, 11:46:25 PM
Quote from: BSMIT59 on May 26, 2015, 07:02:16 PM
I'm sorry Bryon, I thought everyone knew that "Original"only pertained to 67's. Everything after that is a copy!!   Lol. Just kidding, don't want to offend anyone (even though it's true)
But I still don't understand your comment.  You said you also have a late 67 Camaro.
Tags with white paint them are known through the 67 model year and even into the early part of the 68 model year.
Post by: BSMIT59 on May 27, 2015, 07:16:41 AM
It seemed to me that there was some question as to when the practice of doing this stopped, so I was just throwing out there that what I consider a late year built 67 to still have this condition on it. Both are Norwood cars. When did they shutdown the plants to switchover to start re-tooling for the 68 line?
Post by: bcmiller on May 27, 2015, 09:04:04 AM
Shutdown in 67 was in July, with things switched over to the 68 model year before the end of August.
And there are some early 68 model year cars with the white tag.  My 68, built in September of 67, is one that seems to have had some white paint on the tag originally.  There are also other 68 tags with the white paint.
