Camaro Research Group Discussion => Originality => Topic started by: incom5633 on October 31, 2006, 04:35:55 PM
Title: 69 350 SS EXHAUST BRACKET
Post by: incom5633 on October 31, 2006, 04:35:55 PM
GOOD AFTERNOON
MY QUESTION CONCERNS A 69, 350SS AUTO BUILD DATE FEB. 69. DO ALL 69 SS 350'S HAVE AN EXHAUST BRACKET WELDED ON DRIVERS SIDE AND OR PASSENGERS SIDE ? MY CAR HAS FACTORY THREADED HOLES ON BOTH SIDES, IN FACT THEY APPEAR TO HAVE A THREADED INSERT IN ALL FOUR HOLES.  THERE IS NO WELDED BRACKET ON EITHER SIDE NOR IS THERE SIGNS THAT THERE MAY HAVE BEEN A BRACKET WELDED ON . I HAVE OWNED THIS CAR SINCE 1971. PLEASE ADVISE
Title: Re: 69 350 SS EXHAUST BRACKET
Post by: william on October 31, 2006, 08:07:27 PM
All 1969 dual exhaust coupes received the reinforcement plate on the LH frame rail only. Convertibles did not need it due to heavier gauge frame rails.
Post by: enio45 on November 05, 2006, 05:06:36 AM
So does that means the car is not an SS car then??  Was it just badged in 71 as an SS??
Post by: JohnZ on November 05, 2006, 10:03:19 AM
What it means is that the car didn't leave the plant with dual exhausts; if it has threaded inserts on both sides for the hangers, they were likely added later.
Post by: enio45 on November 05, 2006, 03:36:43 PM
i was under the impression that if it was a SS 350 CU Inch . .it received dual exhaust?
Post by: Mark on November 05, 2006, 04:19:07 PM
If it was an L48 (350/300HP) then it was an SS and would have had dual exhaust.  If it was an L65 (350/250HP) then it was not an SS and would not automatically have received dual exhaust, but it was available as an extra cost option.
How many fuel lines are under your car?
