Camaro Research Group Discussion => Originality => Topic started by: Mr 396 on January 24, 2015, 07:50:07 PM
Title: '69 Oil Pressure Switch Adapter
Post by: Mr 396 on January 24, 2015, 07:50:07 PM
What adapter is used to screw into a big block to use the oil pressure switch that works the idiot lights in the dash? This is not for a pressure gauge that is in a console.
Title: Re: '69 Oil Pressure Switch Adapter
Post by: L78 steve on January 24, 2015, 08:32:35 PM
2 or 4 bolt block?
Post by: 1968 Z28 on January 24, 2015, 08:49:43 PM
I presume you are referring to the "Elbow".....there are two listed in the parts manual.
    1.  #3954219 - 1969/396  325hp or 350hp   (There was a note on the Aim that there was another part number used earlier and the number for it was #444052)
    2.  #3954220 - 1969/396  375hp
Here is a link that shows the elbow #3954219.......http://www.yenko.net/ubbthreads/ubbthreads.php/topics/581053/big-block-oil-fitting-brass-el (http://www.yenko.net/ubbthreads/ubbthreads.php/topics/581053/big-block-oil-fitting-brass-el)
Post by: Mr 396 on January 24, 2015, 10:00:28 PM
Thanks. That is exactly what I was looking for.
