Camaro Research Group Discussion => Restoration => Topic started by: Mike S on August 26, 2014, 10:10:04 AM
Title: Extent of firewall coverage with body paint
Post by: Mike S on August 26, 2014, 10:10:04 AM
 I'm at the point of spraying the door jambs, underside of trunk lid and lip and firewall prior to body spray. How low did the robotics spray paint on the firewall prior to blackout?
Were the bottom of the "saddle bags" and the angular looking lower fender support covered in body color too prior to blackout? This is for a 67 NOR car.
Thank You,
Title: Re: Extent of firewall coverage with body paint
Post by: mickeystoys69RSSS on October 05, 2014, 03:40:55 PM
Mine is an original unrestored. You can see the fade line around the mid to top of the trim tag. You can barely see the T proof stamp so you can tell it had been untouched except some PO scrubbed the trim tag.
